Matlab Signal processing
Discussion in 'Programmer's Corner' started by BuriedMoon, Mar 29, 2010.
  1. BuriedMoon
    Mar 2, 2010
    22
    How do i find the start and the end of the envelope from an audio signal ?
  2. johndoe45
    Member
    Jan 30, 2010
    364
    if variable is like t for time
    then type t(1) in command window
    and maybe t(end)
    might work
    or t(length(t))
  3. BuriedMoon
    Mar 2, 2010
    22
    Is it going to work?
    Cause basically i'm using hilbert transform to extract the envelope for the speech signal .
  4. johndoe45
    Member
    Jan 30, 2010
    364
    i don't know. never tried it. but t(1) is initial time
    and t(length(t)) is final time
    variable could be x or anything so i don't know without seeing the function.
    i think its n(1)
    n(end) or n(length(n))
    just try it and see if it gives you anything.
    this is just how many points are taken. but to compute the time i wouldn't know
    just look at the side and it has has how long the arrays or vectors are
    will say like 1 x 100 which means one row with 100 columns. so 100 elements
    fh=[0:Lh-1]/Lh-0.5
    therefore x axis is from 0 to length(Hh)-1
    so type length(Hh)-1 and returns final value
    i don't know
    check this site out
    https://ccrma.stanford.edu/~jos/sasp/Comparison_use_hilbert_function.html
  5. BuriedMoon
    Mar 2, 2010
    22
    if gives undefined variables..:)
    Do you want me to post up my m-file for you to read up ?
  6. johndoe45
    Member
    Jan 30, 2010
    364
    yes please. hurry. i'm tired
  7. BuriedMoon
    Mar 2, 2010
    22
    function [data,fs,smoothData] = Uload()
    [filename, pathname] = uigetfile('*.wav','Select Data File');
    if filename ~= 0
    cd(pathname);
    % Get data and sampling rate
    [data,fs] = wavread([pathname filename]);
    % length(data)
    % fs
    data = data/max(data:)));
    hwin1 = subplot(221);
    xlabel('Samples')
    ylabel('Signal (Volts)')
    ldata = length(data)
    tdata = 1:ldata;
    cdata = hilbert(data);
    [b,a] = butter(5,20/(fs/2),'low');
    smoothData = filtfilt(b,a,abs(hilbert(data)));
    plot(tdata,2*smoothData,tdata,abs(cdata))
    hwin2 = subplot(222);
    % [b,a] = butter(5,20/(fs/2),'low');
    % smoothData = filtfilt(b,a,abs(hilbert(data)));
    % plot(smoothData)
    p = fft(data);
    ls = length(p);
    x=abs(p((1:ceil(ls/2))));
    plot(hwin2,x)
    % if min(size(data))>1
    % error('Can''t load stereo data')
    % end
    end
    %is one of the function to call back for one of my uicontrol to load a wavfile and display the timewaveform (together with the envelope ) , frequency domain (spectrum) as well .
  8. johndoe45
    Member
    Jan 30, 2010
    364
    so output variables are these [data,fs,smoothData]
    this is initial to final data points
    tdata = 1:ldata;
    so type ldata and will give you final pretty sure
    can't even find fs=...... in that mess
  9. BuriedMoon
    Mar 2, 2010
    22
    yes , indeed ..=)
  10. johndoe45
    Member
    Jan 30, 2010
    364
    so you got it?
    and its correct for sure?
    cause it might be max(length(b)-1,length(a)-1)
    check this out and look at NOTE PORTION IN RECTANGULAR BOX!!!!!!!!!!!!!!!!!!
    http://www.mathworks.com/access/helpdesk/help/toolbox/signal/filtfilt.html
    but in your program i think that is the max height for first graph
    because you have plot(tdata,2*smoothData) so x is bottom and 2*smoothData is top
    there fore x axis is 1:ldata and y axis is -2*(max(length(b)-1,length(a)-1)):2*(max(length(b)-1,length(a)-1))
  11. BuriedMoon
    Mar 2, 2010
    22
  12. BuriedMoon
    Mar 2, 2010
    22
    It looks like 1data gives you the whole length of the data ...
  13. johndoe45
    Member
    Jan 30, 2010
    364
    read my previous post.
    so want to achieve time?
  14. BuriedMoon
    Mar 2, 2010
    22
  15. johndoe45
    Member
    Jan 30, 2010
    364
    i did. its same thing your doing except your version has n data points instead of time on bottoms. right?
    well attach your wav file if can or upload it to a website and post link, pm, something, email cause i have no idea what your talking about without running the program. never done this before
  16. BuriedMoon
    Mar 2, 2010
    22
    Yeah it is i suppose (sorry i'm pretty bad at MAtlab ) =(
  17. johndoe45
    Member
    Jan 30, 2010
    364
    i only have like 3 months experience but have done lots of examples. read previous
  18. BuriedMoon
    Mar 2, 2010
    22
    Ok let me extract it and send it to you
  19. BuriedMoon
    Mar 2, 2010
    22
    Can you give me your email ?
  20. johndoe45
    Member
    Jan 30, 2010
    364
    you send it to me yet? i think i sent you my email like 3 times cause doesn't show up under my sent messages
    when is this due. i'm tired. if can't figure it out in next ten minutes i'm probably going to bed.
