matlab programming/error messages
Discussion in 'Homework Help' started by chrill3123, Sep 30, 2011.
  1. chrill3123
    Apr 21, 2010
    9
    My function in matlab is:
    t=0:0.01:8;
    w=1;
    y=1-((exp(-0.6*w*t))/(sqrt(1-0.6^2)))*sin(w.*sqrt(1-0.6^2)+acos(0.6));
    plot(t,y);
    hold on;
    w=5;
    plot(t,y)
    but every time I´ll run it I get the following message:
    ??? Error using ==> mtimes
    Inner matrix dimensions must agree.
    Error in ==> Analytiskt_w0_w5 at 3
    y=1-((exp(-0.6*ω*t))/(sqrt(1-0.6^2)))*sin(ω.*t.*sqrt(1-0.6^2)+acos(0.6));
    I don´t see where I do wrong:mad:
    Any help is appreciated
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Your code works to me in Matlab R2010b and its output graph is attached.
  3. Chrill3
    Mar 8, 2010
    9
    Iam sorry I gave you the wrong function the correct one is, and with this I get the error message from matlab:
    t=0:0.01:8;
    w=1;
    y=1-((exp(-0.6*w*t))/(sqrt(1-0.6^2)))*sin*t*(w.*sqrt(1-0.6^2)+acos(0.6));
    plot(t,y);
    hold on;
    w=5;
    plot(t,y)
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    That doesn't make much sense, now, does it? What is the meaning of the multiplication sin*t. Did you mean sin(t*...)?
    Please properly post your function.
  5. Chrill3
    Mar 8, 2010
    9
    I did find the solution to this problem it is:
    y=1-((exp(-0.6*w*t))/(sqrt(1-0.6^2))).*sin*t*(w.*sqrt(1-0.6^2)+acos(0.6));
    I needed an dot after (sqrt(1-0.6^2))).* for the matrix multiplication to work correctly
