MATLAB program error help
Discussion in 'Programmer's Corner' started by killer6008, Feb 1, 2010.
  1. killer6008
    Jan 26, 2010
    20
    Helllo
    I am trying to find a problem with this program.
    This is the question I was given:
    Using the MATLAB function integ (below) write an m–file to calculate the first 50 pairs of coefficients An and Bn which express a saw-tooth wave as a Fourier Series. Your code should define one period of the saw-tooth wave x(t) and call the function integ to perform the appropriate integration.
    function [area] = integ(x,t)
    % integ is a function which calculates an approximation
    % to the integral of x(t) between the limits t(1) (the
    % first value of the array t) and t(end) (the last value
    % of the array t). It is assumed that the points in t are
    % equally spaced a distance dt apart.
    area=0;
    dt=t(2) – t(1);
    for k=1:length(x)-1,
    area = area + (x(k)+x(k+1))*dt/2
    end;
    This is what I have written:
    Code for 50 coefficients:
    dt =0.0125
    t = [-0.5:dt:0.5];
    s=t;
    y=0;
    T = 1;
    f = 1/T;
    for n = 1:1:50
    x= cos(2*pi*n*f*t);
    xa=s.*x;
    a(n)=2*integ(xa,t);
    z= sin(2*pi*n*f*t);
    xb=s.*z;
    b(n)=2*integ(xb,t);
    end;
    for k= 1:1:50
    y=y + a(k)*(cos(2*pi*k*f*t))+ b(k)*(sin(2*pi*k*f*t));
    end;
    plot (t,y);
    Its giving an error when you run it.
    Can someone help me to fix this please? This is all the code there is to it.
    Thankss
  2. guitarguy12387
    Apr 10, 2008
    359
    12
    Well it would help to know what error it is giving you.
