Matlab problem
Discussion in 'Programmer's Corner' started by kulin143, Nov 25, 2009.
Thread Status:
Not open for further replies.
  1. kulin143
    Nov 25, 2009
    calculate anda plot the forward current voltage characteristics of a p-n silicond diode at T=300K,taking into account the recombination current in the depletion region.Use the following parameters Na=10^17 (cm)^-3,Nd=10^15 (cm)^-3,Eg=1.12 eV,Nc=3.22*(10)^-19 (cm)^-3,ε=1.054*(10)^-10 F/m,Device area is s=(10)^-4 (m)^2 , μp=0.04 (m^2/Vs) and μn=0.1 and τ=10^-8 s.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Just substitute these values in the formulas given to you. If you do it right you should come with a two variables equation and then let matlab plot the graph.
  3. kulin143
    Nov 25, 2009
    hi mik,thank you very much for ur reply but the problem is i donno the matlab and my homework submission date is very near so i request you kindly to just tell me how to solve the problem in detain and kindly try to able to gimme the matlab code for the above problem.THANKS mik
  4. JoeJester
    Apr 26, 2005
    3,401
    1,218
    It would be time you and Matlab get aquainted. The submission date is very near and getting closer as I type.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Does that mean you will give any marks you get to mik3? This is suspiciously similar to another currently active thread where the member is just wanting Matlab code for little/no work.
    This forum is not a dumping ground for you to have your work done by someone else, we will help but you must dictate the course of your own learning. Your urgency is of no concern to anyone here. Have a read of this and try again.
    Dave
Thread Status:
