Matlab problem: stuck on printing out a measurement at a certain time please help
Discussion in 'Programmer's Corner' started by saruji, Apr 7, 2012.
  1. saruji
    Oct 18, 2011
    14
    so slightly stuck on a problem:I am given a data set, whos first column is time from 0-19 seconds with 1 second intervals, the columns 2:6 have various sensor measurements. I am asked to extract the min measurement and the max measurements for each sensor and then use MatLab to determine at what time they occurred... stuck on finding out at what time they occurred, any help would be greatly appreciated, thanks
    attached the sensor.dat file
    my code so far:
    http://pastebin.com/xRZHNikn
    or for quick reference of my code so far
    %Read the data file and print the number of sensors and the number of
    %seconds of data contained in the file. Before that load the sensor.dat
    %file
    load('sensor.dat')
    [seconds, sensors] = size(sensor)
    %Problem 4.4b
    %Found both the maximum value and the minimum value recorded on each
    %sensor, and showed at what time they occured.
    max1 = max(sensor:), 2))
    max2 = max(sensor:), 3))
    max3 = max(sensor:), 4))
    max4 = max(sensor:), 5))
    max5 = max(sensor:), 6))
    min1 = min(sensor:), 2))
    min2 = min(sensor:), 3))
    min3 = min(sensor:), 4))
    min4 = min(sensor:), 5))
    min5 = min(sensor:), 6))
    time = sensor:), 1)
    sensor = sensor:), 2:6)
    ???? not sure on how to proceed
  2. panic mode
    Oct 10, 2011
    1,328
    305
    max1=sensor(1,1);
    max1time=1;
    for i=2:N
    if sensor(i,1)>max1
    max1=sensor(i,1);
    max1time=i;
    end;
    end;
  3. saruji
    Oct 18, 2011
    14
    thank you, I solved it a different way.
    max1 = sortrows(sensor, -2);
    max1_value = max(sensor:), 2))
    time_at_max1 = max1(1, 1)
    I sort a sensor column in descending order and then print out the readings from the top columns for the needed column.
