Matlab plotting
Niel Hong
Joined Jul 24, 2013
Hi guys, I have a problem here. Need some experts to guide me.
I have a parallel resonant circuit with variable capacitance, and need to get it magnitude response in Matlab.
At fr=198kHz, C max=2064.5pF ; fr=304kHz, C min=2062.2pF
R=11 ohms, Q=35, L=0.25uF
I've tried to get the magnitude by varying the frequency from 160kHz to 400kHz, but all I got was just dots, nothing was being shown.
I know the Current is extremely small, is there any possible way to have the magnitude of I against frequency by using Matlab?
Niel Hong
Joined Jul 24, 2013
Hi Joe,
Thanks for your reply.
Question: A variable Capacitor needed to adjust the designated resonant frequency over the band by giving fr1=198kHz and fr2=304kHz with Q=35 at one end of the band, and Q≤35 throughout the band. Let R=11Ω, and specify the values for L, Cmin, Cmax. Using matlab to draw the magnitude response of the resonant circuit for both values of C.
My calculation for L, Cmin, Cmax:
Q=R/XL
XL=R/Q
L=R/2*pi*fr*Q
L=0.25uH
From formula, fr=(1/2pi)*[√(1/LC)-(R^2/L^2)]
I got,
C=1/L [ (2*pi*fr)^2 + (R^2/L^2) ]
then,
substitute fr1,
Cmax=2064.5pF
substitute fr2,
Cmin=2062.2pF
These are the calculations that I've done. I've tried using MultiSim, AC analysis to get the current curve. But with the capacitance that I assigned, the resonant current isn't at between Cmax and Cmin. For Matlab part, after keying and run the .m file, it shows nothing in the figure.
Did I make some mistakes?
JoeJester
Joined Apr 26, 2005
4,390
Q=R/XL
XL=R/Q
L=R/2*pi*fr*Q
L=0.25uH
I got,
then,
substitute fr1,
Cmax=2064.5pF
substitute fr2,
Cmin=2062.2pF
Did you cross check your answers by using the correct formula for fr?
fr = 1 / (2*pi*(LC)^.5)
It would have been nice to have all the information you were provided to start this problem. It sounds like a homework problem to me.
JoeJester
Joined Apr 26, 2005
4,390
You need to be "realistic".
When you figure out components you will need, then go to mouser.com or digitkey.com and select the actual one's you would use if you built the circuit.
Then begin the process of analyzing that circuit to be within your objective.
