Matlab parachute
Discussion in 'Programmer's Corner' started by Bigcountry, Aug 30, 2014.
  1. Bigcountry
    Thread Starter Active Member
    Jul 4, 2008
    71
    I have to create a function then execute it in the command window.
    I need to find "c" by graphic means.
    I am starting at something like this :
    a = fnval(dummy,c)
    fnval(c,dummy)
    fnval(...,'l')
    The program works if I plug in some value for "c" in the equation. I just need to figure out how to get it to use an infinite amount of values.
    thanks for any help.
    function dummy=parachute(c)
    m=68;
    g=9.81;
    t=10;
    v=45;
    dummy=-v+(g*m./c)*(1-exp(-c/m)*t);
    fplot('parachute',[0,20])
    grid on
    xlabel('c')
    ylabel('f(c)')
    end
  2. shteii01
    Feb 19, 2010
    3,505
    512
    Why don't you define c?
    c=0:0.1:10000;
    The first value of c is zero. Then c is incremented by 0.1, so new c is 0.1. Then c is incremented again, new c is 0.2. And so on until you reach 10000. You graph will have 100,000 points.
    Hmm, I guess you don't want to divide by zero. Then you can do this:
    c=0.1:0.1:10000;
  3. Bigcountry
    Jul 4, 2008
    71
    Thank you! I always have a hard time getting started. Now I have to figure out how to create a function to find "c" at 10 seconds on the graph. This is a good start.
  4. Bigcountry
    Jul 4, 2008
    71
    Now I am getting an error message.
    Maximum recursion limit
    of 500 reached. Use
    set(0,'RecursionLimit',N)
    to change the limit. Be
    aware that exceeding
    your available stack
    space can crash MATLAB
    and/or your computer.
