Matlab, modelling a 555.
Discussion in 'Programmer's Corner' started by THCynical, Dec 9, 2014.
  1. THCynical
    May 5, 2014
    26
    Stuck again,
    The question is quite long, I've only included the part I need help with.
    I have to model a 555 and produce this graph
    I don't know how to alternate between the two formula.
    I have written in English
  2. THCynical
    May 5, 2014
    26
    clc
    clear
    t=1:1:100; %time
    R1=1000; %temp presets
    R2=1000;
    C1=0.000001;
    Vcc=10;
    Vi=0; %Vi should vary
    Vf=10; %Vf should vary
    f = 1.44/((R1+(2*R2)).*C1); %frequencey
    d = (R1+R2)/(R1+2*R2); %duty cycle
    VCcha = Vf.^(1-exp(-t./(R1+R2)*C1)); %Vc charge
    VCdis = Vi.*exp(-t/R2*C1); %Vc discharge
    This is triangle
    %while time passes
    %1 VC = VCcha, until VCcha reaches ((2/3)*Vcc) THEN 2
    %2 VC = VCdis, intil VCdis reaches ((2/3)*Vcc) THEN 1
    %end
    this is square
    %if VC =((2/3)*Vcc) then Vo=Vcc
    %esleif VC=((1/3)*Vcc) then Vo=0
    %end
    fprintf('Frequencey = %g Hz\n',f);
    fprintf('Duty Cycle = %g \n',d);
    plot(t,VCcha,t,VCdis)
    title('555 Astable Multivibrator')
    xlabel('Voltage(V)')
    ylabel('Time(s)')
    grid on
  3. THCynical
    May 5, 2014
    26
  4. WBahn
    Mar 31, 2012
    18,089
    4,917
    You can alternate between two cases with a state variable and an 'if-else' statement.
  5. THCynical
    May 5, 2014
    26
    Cheers WBahn, there's more to this than i thought, i will spend another while at it, but the problem relates to time (t)
    I believe it needs to be a while loop, switching between charging and discharging, If statements setting conditions.
    But time for the dis/charge equations needs to reset to zero at each change for the equations to work.
    Some of my problem also, is just figuring out the syntax needed. as i say ill try put together something functional and report back.
  6. WBahn
    Mar 31, 2012
    18,089
    4,917
    What you are basically writing is a simulator, albeit a very simple one. So your main loop does nothing except increment time by some small amount and you keep track of the voltages at the key nodes and what state you are in. Then in each increment you calculate how much current is flowing and how much the node voltages change and then whether the state changes and you update all of those before moving on to the next time increment.
