Matlab Lab, Check answers and need some help
Discussion in 'Programmer's Corner' started by Judas543, Mar 26, 2010.
  1. Judas543
    Jan 26, 2010
    60
    Copy separate into a new .m file
    If someone could check over this and help me with the needed parts then that would be great. It's due before 10 PM EST
    #1) Write a Matlab function that takes a string(short sentence) as its input and returns a string where all the occurrences of "blanks" are replaced with "-". The function is then be used in a script asking the user to enter a short sentence, and then displays the modified string.
    Main Script
    clc %clear command
    clear %clear workspace
    myString = input('Type a sentence (between single quotes):'); %Input Sentence
    [Blank] = replace(myString);
    Function Script
    function Blank = blank1(myString)
    for Blank = 1:length(myString)
    if myString(Blank) == '-'; %If myString has a space then replace with (-)
    myString(Blank) = ' '
    end
    end
    2) Write a function that returns the positions of the "blank spaces" in a sentence entered by the user.
    %For this one I just kept the same input and change the "-" and replace with " ".
    However is there another way of doing this if the two questions are independent?
    3)Enter your name. The matlab script displays your name spelled backwards.
    Ex: user types in john
    returns john
    Hello nhoj
    clear
    clc
    myName = input('What is your name (between single quotes):'); %e.g Input mike
    fliplr (myName)
    %I used fliplr built in function.. However I would like to know how to do it without the built in function.. You can do it with the for loop but i need help finishing it up...
    for k = length(myName):-1:1
    %something like newName(k) = myName(k-1) dunno Please help
    end
    4)Write a matlab script that asks the user to enter a noun, and the program displays: "the plural of noun_entered is: noun_entereds"
    clc
    clear
    noun = input('Please enter a noun (between single quotes):') %Input a Noun
    Nplural = [noun,'s'] %Adds a 's' to your noun
    fprintf('The plural of your noun is %s \n',Nplural) %Print Result
    %However i want it to say the plural of the word is words... With script for #4 is there a way to do that?
    5)Write a function that soncerts to uppercase all the letters of a word(assumed to be entered in lowercase)
    This is easily done with upper built in function but is there a way to do it another way. My professor gave us a hint and said look at an ASCII table
  2. johndoe45
    Member
    Jan 30, 2010
    364
    3.)
    clc
    clear all
    close all
    x=['john']
    y = x:),length(x):-1:1)
    MATLAB OUTPUT
    x =
    john
    y =
    nhoj
  3. johndoe45
    Member
    Jan 30, 2010
    364
    1.)
    x='john doe'
    for i=1:length(x)
    if x(i)==' '
    x(i)='-';
    end
    end
    x
    MATLAB OUTPUT
    x =
    john doe
    x =
    john-doe
  4. Judas543
    Jan 26, 2010
    60
    thanks, finished it
