MATLAB image processing desperate for help
Discussion in 'Homework Help' started by princesstina, Jun 26, 2014.
  1. princesstina
    Jun 26, 2014
    I found this forum and i desperatly need help.We got homework to make some filters but i have never seen all that and i dont know where to start.Could anyone help me and write how to do it?I already have a grade from this but i have to give him this to go on other subjects...Please...
    RESTORATION OF DEGRADED IMAGES
    * In a system for image acquisition comes often to a lesser or greater damage to the image caused
    imperfections of the device which performs the recording. The object of this project is the implementation of
    system for the restoration of images degraded by passing through the system shown in Figure 1. description
    individual blocks is given below.
    Change the size and
    geom. degradation
    linear
    transformation
    pixels in HSV
    space
    Input image Batervortov NF
    first-order filter
    DCT kvatizacija and
    run-length
    coding
    The output image
    Fig.1. Image processing system
    * The first block is transformed dimensions of the input image and enter the geometric degradation.
    Dimensions of input color images are 512x512 pixels, and after leaving the block dimensions are
    640x480 pixels (width x height). Device acquisition brings and geometric degradation. Specifically,
    focus image point with coordinates (256.5, 256.5), is mapped to a point with coordinates
    (280.5, 180.5), so that the four triangles of the left figure in FIG. 2 affine mapped to
    corresponding triangle in the right figure (see cp2tform function in MATLAB).
    (256.5, 256.5)
    (280.5, 180.5)
    Fig.2. Transforming the size of the input image and geometric degradation
    * In the second part of the system is Hue component images in the HSV color space is replaced
    their negatives.
    * The third block is Batervortov first-order low-pass filter, which is implemented as a separable filter
    (a separabilnih filter applies that H (u, v) = H1 (u) H2 (v)). Limit frequency filters H1 (u) and
    H2 (v) amounts uc = 40 in the horizontal direction and vc = 20 in the vertical.
    * The last block performs image compression before the final track on the disc. Image compression is performed
    in the transformation (DCT) domain. Prior to joining the DCT domain, the image is transferred from the RGB
    color space, suitable for compression, YCbCr color space (see function rgb2ycbcr)
    is executed and then the decimation factor of 2 and the second picture of a third channel (Cb and Cr). each channel
    is divided into 8x8 sub-picture size and is calculated for each DCT transform. The resulting
    DCT coefficients are quantized using a quantization matrix given in Tables 1 and 2
    Applied as a separate quantization tables for luma (Y) and hrominentne channels (Cb and Cr). SMER of Communication Technologies and Signal Processing
    TERMS OF REFERENCE FOR DIGITAL IMAGE PROCESSING (Sk. 2013/14. GOD.)
    Each 8x8 block konvertivan in a series of 64 quantized DCT coefficients zigzag scanning
    (see Table 3). Run-length coding sequence obtained was performed by a prescribed
    DC value, and each non-zero AC component is registered as a couple with the number of zeros that her
    preceded by a zig-zag line. The last recorded pair (number zero, non-zero AC coefficient) in the block
    actually describes a final sequence of zeros that is spread to the end of the block, and therefore in this case of the
    Place AC value is a zero, which actually represents the label to arrive at the end of the
    block. All run-length encoded DCT coefficient arrays housed in one long string, so
    they are first placed run-length arrays of Y channel (their number is 4800), then the Cb channel
    (1200 series) and at the end of the Cr channel (1200 series, as well as in Cb). The resulting series is filmed
    R as a variable in the MATLAB file projekat.mat. (The variable R is loaded into the MATLAB working
    space reference instructions load projekat.mat when this file is located in the working directory
    Or simply drag (drag-and-drop) the file projekat.mat the MATLAB workspace.)
    Table 1 quantization table for the luma channel (Y) Image
    Table 2 quantization tables hrominentne channels (Cb and Cr) image
    Table 3 matrix that defines the zig-zag scan
    16 11 10 16 24 40 51 61
    12 12 14 19 26 58 60 55
    14 13 16 24 40 57 69 56
    14 17 22 29 51 87 80 62
    18 22 37 56 68 109 103 77
    24 35 55 64 81 104 113 92
    49 64 78 87 103 121 120 101
    72 92 95 98 112 100 103 99
    17 18 24 47 99 99 99 99
    18 21 26 66 99 99 99 99
    24 26 56 99 99 99 99 99
    47 66 99 99 99 99 99 99
    99 99 99 99 99 99 99 99
    0 1 5 6 14 15 27 28
    2 4 7 13 16 26 29 42
    3 8 12 17 25 30 41 43
    9 11 18 24 31 40 44 53
    10 19 23 32 39 45 52 54
    20 22 33 38 46 51 55 60
    21 34 37 47 50 56 59 61
    35 36 48 49 57 58 62 63
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    In Homework Help, we do not do your homework for you. We do not write code for you.
    Show us your best effort and we can take it from there.
    Explain what you have done and with what you are having difficulty.
