MATLab help?
Discussion in 'Math' started by srinath.msd, Jan 24, 2014.
  1. srinath.msd
    Sep 19, 2011
    5
    hey guys..
    i need to compute the mathematical model of a transfer function using simulink in matlab.. however i first have to convert it into a state space model.. need some help with this one as i dont know state space modeling very well...
    the transfer function is:
    25.04s + 2.008/s^3 + 5.0325s^2 + 25.1026s + 5.008
    thanks in advance..:)
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Your transfer function seems to have two terms in 's'. Are you sure you've transcribed it correctly?
    You don't know state-space modelling. Time to do some self-study.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Actually, Matlab allows for not studying in this case, if you are specific enough.
    Given a transfer function
    G(s)=\frac{A(s)}{B(s)}
    you can insert it into Matlab and create an LTI system block out of it by typing:
    Code ( (Unknown Language)):
    1. G=tf([an ... a2 a1 a0],[bm ... b2 b1 b0])
    Then, you can convert this TF into a space-state system with
    1. G1=ss(G)
    The opposite is true as well:
    1. G2=tf(G1)
    Here are some references:
    http://www.mathworks.com/help/control/ref/tf.html
    http://www.mathworks.com/help/control/ref/ss.html
