Matlab help
Discussion in 'Programmer's Corner' started by ignite, Jan 14, 2009.
  1. ignite
    Jan 31, 2008
    18
    Is there a function in mathlab which will calculate the phase of a sinosidal waveform or the phase difference between two sinosidal waveforms????
  2. mik3
    Feb 4, 2008
    4,846
    63
    To put these sine waves in Matlab it means you know their equations. If this is the case then you can calculate the phase without Matlab.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Have you considered doing a Hilbert Transform, using the function hilbert (requires the signal processing toolbox), and then analyse the phase relationship from each analytic pair with respect to time.
    Dave
