ppl,,
i made a project in matlab on image processing.... it reads a image and changes it through some code... which is not important...
The problem is that when i run my project through matlab command window,, the desired results are produced in nearly 15 sec... which is quite fine...
Now I created a stand alone executable file by ..
mcc -m project.m -o project
an .exe file with some .c files are created.. Now when I run this .exe,, the results are produced right but...
It is taking more than 2-3 mintes may be 4.... I don know what is happening... What I know i s that it's consuming most of its time in processing imread('image.jpg')....
I don kno what to do to get it running as fast as it does in the command window of matlab.....
Plz help,, any help is appreciated..
Thanks in advance
Thanks in advance
