This is the starting point, when it records it will play the waveform for time domain and frequency and there are buttons for you to save and load as well . However , whenever i wanted to load a file., the waveform doesnt show. Anyone
here can enlighten me would be great .
_________________________________________________________________
global H_RECORD%main program
global F_RECORD
width = 950;
height = 700;
F_RECORD = figure('Position',[25 50 width height],...
'NumberTitle','off',...
'Color',[.8 .8 .8],...
'Name','Record');
H_RECORD = uicontrol('Style','pushbutton',...
'Units','normalized', ...
'Position',[(width-450)/width (height-40)/height 80/width 25/height],...
'ForegroundColor',[.2 .4 .2],...
'FontWeight','bold',...
'String','Record',...
'Enable','off',...
'CallBack',['data = record_sound1(4);',...
'hwin1 = subplot(2,1,1);plot(data);xlabel(''Samples'');ylabel(''Signal (Volts)'');',...
'hwin2 = subplot(2,1,2);p = fft(data);plot(abs(p((1:2*fs))));xlabel(''Frequency(Hz)'');'...
'ylabel(''Magnitude'');']);
H_PLAY = uicontrol('Style','pushbutton',...
'Position',[(width-150)/width (height-40)/height 80/width 25/height],...
'String','Play',...
'Enable','off',...
'CallBack',['xlim = get(hwin1,''XLim'');xlim(1) = max([xlim(1),1]);xlim(2)=min([xlim(2),length(data)]);sound(data(xlim(1):xlim(2)),fs)']);
H_ZOOM = uicontrol('Style','pushbutton',... % zoom
'Units','normalized',...
'Position',[300/width (height-370)/height 80/width 25/height],...
'ForegroundColor',[1 0 0],...
'String','Play',...
'String','Zoom in',...
'Visible','on',...
'CallBack','mycallbackplot');
H_SAVE = uicontrol('Style','pushbutton',... % save button
'Position',[580/width (height-40)/height 80/width 25/height],...
'String','Play',...
'String','Save',...
'Visible','on',...
'CallBack',['xlim = get(hwin1,''XLim'');xlim(1) = max([xlim(1),1]);xlim(2)=min([xlim(2),length(data)]);' 'mysave(data(xlim(1):xlim(2),,fs)']);
H_LOAD = uicontrol('Style','pushbutton',... % load button
'Position',[660/width (height-40)/height 80/width 25/height],...
'String','Play',...
'String','Load',...
'Visible','on',...
'CallBack','myload(data,fs)');
fs = 11025;
% ts = 10;
% AI = analoginput('winsound');
% addchannel(AI,1:2);
% set(AI,'SampleRate',fs)
% set(AI,'SamplesPerTrigger',ts*fs)
% start(AI)
% data = getdata(AI);
data = zeros(4*fs,2);
% t = (04*fs-1))/fs;
set(H_RECORD,'enable','on');
set(H_PLAY,'enable','on');
set(H_ZOOM, 'enable', 'on');
set(H_LOAD, 'enable', 'on');
set(H_SAVE, 'enable', 'on');
subplot(2,1,1)
plot(data)
xlabel('Samples')
ylabel('Signal (Volts)')
%hold on
subplot(2,1,2)
% f = [(1:2*fs)-1];
p = fft(data);
xlabel('Frequency(Hz)');
ylabel('Magnitude');
% sound(data,fs)
% Data=1:64;Data=(Data'*Data)/64;
%h=msgbox('Loser','Win or Lose','custom',Data,hot(64))
%E = uicontrol('Style', 'pushbutton', 'String', 'Clear',...
%'Position', [20 150 100 70], 'Callback', 'cla');
%delete(AI)
%clear AI
%sstop = round(get(gca,'XLim'));
% sound(data(sstop(1):sstop(2)),fs)
function mycallbackplot%function to plot and zoom in waveform for the %frequency domain
subplot(211)
hchil = get(gca,'children');
data = get(hchil,'YData');
data = [data{1};data{2}];
xlim = get(gca,'XLim');
xlim(1) = ceil(max([xlim(1),1]));
xlim(2)=floor(min([xlim(2),length(data)]));
subplot(212)
p = fft(data(xlim(1):xlim(2)));
semilogy(abs(p(1:0.5*(length(data(xlim(1):xlim(2)))))));
ylabel('dB');
function mysave(data,fs)%callback function to allow it to save .
[filename, pathname] = uiputfile('*.wav', 'Save Data to Wave File');
if filename ~= 0
wavwrite(data,fs,[pathname filename])
end
function myload(data,fs)%call back function for loading wavfiles .
[filename, pathname] = uigetfile('*.wav','Select Data File');
if filename ~= 0
cd(pathname);
% Get data and sampling rate
[data,fs] = wavread([pathname filename]);
% if min(size(data))>1
% error('Can''t load stereo data')
% end
end
global F_RECORD
width = 950;
height = 700;
'Name','Record');
'Enable','off',...
'String','Play',...
'Enable','off',...
'String','Play',...
'Visible','on',...
'String','Play',...
'String','Save',...
'Visible','on',...
'String','Play',...
'String','Load',...
'Visible','on',...
fs = 11025;
% ts = 10;
% start(AI)
subplot(2,1,1)
plot(data)
xlabel('Samples')
%hold on
subplot(2,1,2)
% f = [(1:2*fs)-1];
p = fft(data);
% sound(data,fs)
%delete(AI)
%clear AI
subplot(211)
subplot(212)
ylabel('dB');
if filename ~= 0
end
if filename ~= 0
cd(pathname);
% end
end
