Matlab GUI question
Discussion in 'Programmer's Corner' started by Ron_7, Mar 13, 2007.
  1. Ron_7
    Dec 18, 2006
    8
    hello guys,
    just wondering if anyone knows how to output the contents of a .dat or .txt file into a text box in a matlab gui.
    i've used the following to create a .dat or .txt file.
    fiw = fopen('watermarks.txt','wt');
    fprintf(fiw,'\n watermark # %d = %s position = %d',kk,str,POSITION(kk));
    i'm currently outputing to the command window using :
    disp(sprintf(' watermark # %d = %s position = %d',kk,str,POSITION(kk)));
    Thanks in advance
    Ron
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    If the text you wish to write to the text box is in String format then just set the handles for that textbox. For example:
    If you have a textbox called textbox, and the String that you wish to write to it is in the variable var, then to write the String to the text box you would write:
    set(handles.textbox,'String'
    ,var);
    When the function to create/update the textbox/GUI is called the text will be written to the textbox.
    Dave
  3. Ron_7
    Dec 18, 2006
    8
    Many Thanks Dave ur a star. This has done the trick!
