MATLAB: getting the reminder of polynomial division
Discussion in 'Programmer's Corner' started by walid el masry, Jul 3, 2010.
  1. walid el masry
    Thread Starter Active Member
    Mar 31, 2009
    132
    "Header Check Sequence
    An 8-bit field used to detect errors in the header.The transmitter shall calculate the HCS value for the first five bytes of the cell header, and insert the result into the HCS field (the last byte of the MAC header). It shall be the reminder of the division (Modulo 2) by the generator polynomial D^8 + D^2 + D + 1 of the polynomial D^8 multiplied by the content of the header excluding the HCS field."
    how to do that in matlab ?
  2. walid el masry
    Mar 31, 2009
    132
    thnx for all who tried to help me, the solution is
    Code ( (Unknown Language)):
    1.
    2. % get the remoner of division of the input by genpol polynomials
    3. function rem = binary_rem(input, genpol)
    4. %input = [0 0 0 1 0 0 0 0 1 1 0 0 1 1 0 0 ];
    5. %genpol= [1 0 0 0 0 0 1 1 1];
    6. input = [input zeros(1,length(genpol)-1) 0];
    7. temp=input(1:length(genpol));
    8. for i=1:length(input)-length(genpol);
    9.     if temp(1) == 1;
    10.         q(i) = 1;
    11.         output = xor(temp,genpol);
    12.     else
    13.         q(i) = 0;
    14.         %output = xor(temp,not(genpol));
    15.         output = temp;
    16.     end
    17.     temp = [output(2:end) input(length(genpol)+i)];
    18. end
    19.
    20. rem = temp(1:end-1);
    21. end
    22.
