Matlab- Find num and den
Discussion in 'Programmer's Corner' started by cloud, Dec 15, 2006.
  1. cloud
    Dec 15, 2006
    11
    I have a transfer function called tf(1:43001). How do I obtain the
    numerator and the denominator, so that I can use fvtool(num,den)?
    Thank you.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I cannot be specific beacuse I haven't got your transfer function to hand, but you could use the numden function in the Symbolic Math Toolbox (most Matlab installations have this installed as standard).
    Code ( (Unknown Language)):
    1. [n,d] = numden(tf);
    Will return the numerator, n, and the denominator d.
    Failing that you could probably look at deriving the numerator and denominator during the derivation of the transfer function. Could you load up you code to let us have a look at it?
    Dave
  3. cloud
    Dec 15, 2006
    11
    Attached is my code. I will like to find the num and den of my transfer function to design into a filter and to obtain an accurate frequency response. Do you have any suggestions to derive an accurate frequency response for my code?
    Thank you.
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Does that notation imply that the numerator is a 1, and
    the denominator is the polynomial 4x^4 + 3x^3 + 1 ?
    So your question is how to get matlab to give you the individual pieces?
  5. cloud
    Dec 15, 2006
    11
    My tf(1:43001) is refering to the transfer function from 1 data points to 43001 data points. (1:43001) is the number of data points.
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    So this transfer function is defined by a dataset and you want to calculate a rational function with polynomials in the numerator and denominator. Assuming that such a rational approximation exists. I am familiar with polynomial fits but I'm not sure you can find rational approximations to arbitrary data.
    Does your data set have singularities? If it does then those are the roots of the denominator polynomial. Multiply the factors together to get the denominator. Does your data set have zeros? If it does those are the roots of the numerator polynomial. Multiply the factors together to get the numerator polynomial. Except for a possible gain constant, the rest of the points are just floor sweepings and have nothing to do with the transfer function.
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    1. tf=Ysec400c./Ypri400c;  % transfer function=FFT(secondary) / FFT(primary)
    Why is this the transfer function? The transfer function is defined as the output/input of the system H(s) = Y(s)/X(s), so is this correct?
    From what I can gather about your data, tf will be a 1x43001 array of numbers - correct? Therefore you cannot deduce the numerator and denominator of the transfer function from this information. If tf is a 1x43001 array of s-plane parameters then Matlab will allow you to deduce the transfer function directly using the above method in my earlier post.
    Can you write up what data is contained in tf(1:3) as an example?
    Thanks.
    Dave
  8. cloud
    Dec 15, 2006
    11
    Yes, my transfer function is output/input of my system, H(s) = Y(s)/X(s). My tf is a 1x43001 array of data points. I would like to find out the Y(s) and X(s) to represent it as for example, (eg (2s+1)/(s^2+2s+1)). Because I need to perform digital simulations( using Simulink or PSCAD) using the transfer function (eg (2s+1)/(s^2+2s+1)).
  9. Papabravo
    Feb 24, 2006
    10,338
    1,850
    One more time with feeling
    The points are irrelevant. Only the poles and zeros matter.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I concur, from analysing your code the tf array will not provide you the necessary information to derive the transfer function and hence the numerator/denominator for the function fvtool.
    I am also not convinced that dividing your two solutions to the FFT for the secondary and primary constitutes the necessary requirements of the transfer function H(s).
    Dave
  11. cloud
    Dec 15, 2006
    11
    Since my tf=Ysec400c./Ypri400c, how do I represent Ysec400c and Ypri400c into a polynomial respectively?
  12. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Try this as a proposal, I'm not sure how it will work.
    You want H(s) = Y(s)/X(s)
    So: Y(s) = X(s)H(s)
    Think of this in the time-domain: y[n] = x[n]*h[n] (this is convolution)
    You effectly want to perform a deconvolution, Matlab lets you do this with the deconv function:
    1. [h,r] = deconv(y,x);
    Where r is the remainder vector such that y = conv(x,h)+r (hopefully r will be a zero vector, i.e. all zeros).
    The array h is now your impulse response, where by taking the Fourier Transform of h gives the transfer function.
    Dave
