matlab field/column?
Discussion in 'Programmer's Corner' started by Judas543, Apr 25, 2010.
  1. Judas543
    Jan 26, 2010
    60
    You add a new column or field to your database (depending on the format you have decided for your array) that
    contains the “Astrological Sign”. Note: The astrological signs are presented in the “Astrology Chart” at the end of
    this document .
    Now you create a new array (you decide the format) containing the following information:
    The astrological sign (women only)
    The number of women with this astrological sign
    The astrological sign (men only)
    If according to your website wizard a perfect match is “a man and a woman having the same astrological sign”,
    how many “perfect matches” do you have in your database?
    Verify your result: display the matches.
    Uploaded with ImageShack.us
  2. Ghar
    Mar 8, 2010
    655
    72
    Have you used structures before?
    You can have for example:
    Sign(1).name = 'Aries';
    Sign(1).startDate = 'March 21';
    Sign(1).endDate = 'April 20';
    etc.
    Sign(2).name = 'Taurus';
    etc.
  3. Judas543
    Jan 26, 2010
    60
    hmm yes i have, I was confused how the question wanted me to do it ?
  4. Ghar
    Mar 8, 2010
    655
    72
    The question wants you to find how many perfect matches you have.
  5. Judas543
    Jan 26, 2010
    60
    Where do i go after making the structures,
    what will be able to make it so the dates in the database will correspond to the structures I make and help me find the matches? I have ideas forming but it seems hopeless.
    *Also things I dont get...
    The astrological sign (women only) - Means women who have a certain sign only?
    The number of women with this astrological sign -Number of woman with this sign
    The astrological sign (men only) - sign for men only
    The number of women with this astrological sign -WHY THIS appear again?
  6. Judas543
    Jan 26, 2010
    60
    i have no idea how to utilize those structures...
    I mean I have a new array which has the following format: The fifth column I added in which has [] at the end of each row
    Name | Gender | Month | Day | Sign
    So with those structures made that you suggested. I can't think of a way to implement it in a way so that when I enter it somehow... the women with gender F and particular date will be entered in the fifth column
  7. Ghar
    Mar 8, 2010
    655
    72
    The structure I posted was just an example of structures, I don't know if that's a good format or not.
    To check for a match you just need to see how many couples you can make... it's a very simple check.
    #pairs = min( #men, #women)
    (per sign)
    So, with 0 and 0 you get 0.
    With 3 and 2 you get 2 pairs, etc.
