got PM from m_arezoo
do you understand what error tells you?
are you sure your user account on your pc is called HP and not m_arezoo or something similar?
C:\Users\hp\Desktop\abc.wav
are you sure that entire path and file name are correct?
dear m_arezoo, please do not use PM for non-personal matter. I assure you that program is working fine on my machine.hi
i use your matlab code to read audio file but also it has an error, please help me
??? Error using ==> wavread at 166Rich (BB code):[signal, Fs, bits_per_sample]=wavread('C:\Users\hp\Desktop\abc.wav'); L=length(signal); % file length T=1/Fs; % sample period t=[0:L-1]*T; % time vector in seconds % define echo and amplitude values Te=40; % set echo to 300 ms alpha = 0.9; % scale amplitude of echo DelaySec = round(Te / 1000); % must be integer te = round(DelaySec / T); % echo delay as integer (rel. to sample period) signalplusecho=1:L+te; % declare it as vector before loop for t = 1:L+te if (t<te) signalplusecho(t)=signal(t); elseif (t>=L) signalplusecho(t)=signal(t-te); else signalplusecho(t)=signal(t) + alpha*signal(t+te); end end wavwrite(signalplusecho,Fs,8, 'speechwithecho.wav');
Invalid field name: ''.
Error in ==> read at 4
