Matlab Equation
Discussion in 'Programmer's Corner' started by Cerkit, Jan 13, 2010.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. How is it possible to write an equation for example f=X^2 so that anywhere in my code I can get the value of f for a given X by typing
    F(X)
    for some X value?
  2. steveb
    Jul 3, 2008
    2,433
    469
    Simply create a function and put it in an m-file with the same name as your function. For example, for your squaring function chose a name like "Xsquared" for your function and store the function in a file called Xsquared.m. The function code in this m-file would look as follows in this case.
    Code ( (Unknown Language)):
    1.
    2. [FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff]function[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Courier New][SIZE=2][FONT=Courier New][SIZE=2] [output_value] = Xsquared(x)[/SIZE][/FONT]
    3. [SIZE=2][FONT=Courier New]output_value = x^2;[/FONT][/SIZE]
    4. [/SIZE][/FONT][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff][FONT=Courier New][SIZE=2][COLOR=#0000ff]end[/COLOR][/SIZE][/FONT]
    5. [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
    To call the function, simply do the following Y=Xsquared(2) and Y will be set equal to 4 (or the square of whatever value you plug in). Make sure the function file in in your working directory, or keep it in a directory that Matlab can access for functions.
