MATLAB [Dice Game Please Help!]
Discussion in 'Programmer's Corner' started by Judas543, Mar 21, 2010.
  1. Judas543
    Jan 26, 2010
    60
    This script looks easy but from staring at it for countless times and referring to a book, I can't figure it out...I'm really stressing out :(
    Anyways these are the instructions...So you need 1 main script and then a function script
    1.You are playing a game where you roll a die 12 times. In Matlab, you simulate each result by generating a random number between [1...6] (1 point)
    2.If you run a “ONE” or a “FIVE” at least six times, you win 2 dollars, or if you run “THREE” three times you win 1 dollar. (2 points)
    3.Create a Matlab script that calls a function “diceGame” (1 point) that takes in a vector representing the 12 dice values and return the amount of money won.
    I know I have to use this to generate the 6 values ceil(rand * 6);
    need a for loop maybe and a counter.
    Could someone provide the script to this please
  2. t06afre
    May 11, 2009
    5,939
    1,222
    If I solve this do I get the credits;)
  3. Judas543
    Jan 26, 2010
    60
    of course you do
  4. Judas543
    Jan 26, 2010
    60
    has anyone solve this yet X_X
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    When's it due?
  6. Judas543
    Jan 26, 2010
    60
    its due this wednesday. So if anyone can get the answer to this script that would be most helpful
  7. johndoe45
    Member
    Jan 30, 2010
    364
    got this part wrong
    its rand*5+1
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What have you done so far? Post the code you've written.
  9. Judas543
    Jan 26, 2010
    60
    actually I don't really know where to start...
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Start by reading your Matlab manual. They would have sample code in there. Your instructor must have given you some guidance.
  11. Judas543
    Jan 26, 2010
    60
    here some info that I think will help
    % Dice Games Problems:
    % generate random numbers between 0-6
    % Use a For-Loop or a While-Loop to generate a certain number of results
    % Store the results in a vector
    % Cast a die 10 times:
    Results = [ ]
    for k = 1:10
    TempResult = floor(7r * rand(1,1))
    Results = [Results TempResult]
    end
    Results
    % When all the results are stored in the vector “Results”
    % Use a for loop to process each element of “Results”
    For k = 1 : length(Results)
    Do something with Results(k)
    End
  12. johndoe45
    Member
    Jan 30, 2010
    364
    i solved it
    use for loop
    if statements
    the x=round(rand(1,12)*5+1) like i said earlier
    start with this
    this is function file which must be titled dicegame.m in same folder as script file (desktop probably)
    function [money_won]=dicegame(rolls)
    x=round(rand(1,rolls)*5+1)
    this is script file
    rolls=12
  13. Judas543
    Jan 26, 2010
    60
    so would step 2 just be a for loop with if statements? Also is step 3 done?
    Hmm also I get an error when I call the function from my main script. Should I change x to money_won since that is the output
    heres the error
    Error in ==> diceGame at 3
    ??? Output argument "money_won" (and maybe others) not assigned during call
  14. johndoe45
    Member
    Jan 30, 2010
    364
    is function filename dicegame
    can't use money_won yet because that is part you have to make with "for" loop with "if" statement inside, but did it generate the random numbers
    count_a=0;
    for i=1:length(x)
    just to get you started
    and in "if" statement will use count_a=count_a+1;
  15. Judas543
    Jan 26, 2010
    60
    yes it did generate the numbers.
    hmm so if i am rolling the die 12 times then I should start out with
    for i = 1:12
    then the if statements
    end;
    Am i right?
    Also is the function file finished now? And I can conentrate on the main script body
  16. johndoe45
    Member
    Jan 30, 2010
    364
    let me post an example close to it
    at end says plot(t,x)
    || means or and && means and
    so like when x=2 and when x=3
    matlab syntax
    x==2 && x==3
  17. Judas543
    Jan 26, 2010
    60
    hmm alright thanks!
    So after I finish the for loop and the if statements
    +how do I finish up the function file?
    "takes in a vector representing the 12 dice values and return the amount of money won."
    +also could you explain what count does? I read it in the matlab book but it doesnt sit with me still. Does it help keep track what numbers are which
  18. johndoe45
    Member
    Jan 30, 2010
    364
    it is not a function. i just made it up
    so at beginning
    count=0
    now in if statement say
    if x==1 || x==5
    count=count+1
    end
    therefore the count will be 0 at beginning and when a number is either 1 or 5 it will add 1 each time
    then money_won=2*count cause said its 2 dollars
  19. Judas543
    Jan 26, 2010
    60
    alright Ill see what I can get done and post what I have done. Thanks for your time, I really appreciate it !! ^_^
  20. johndoe45
    Member
    Jan 30, 2010
    364
    no problem
    i'm actually taking the class now too
    numerical methods
