MATLAB - deriving frequency response from impulse response
Discussion in 'Programmer's Corner' started by kdillinger, Dec 5, 2009.
  1. kdillinger
    Thread Starter Active Member
    Jul 26, 2009
    141
    I am trying to write a MATLAB routine that will plot the frequency response of a circuit based on the circuits impulse response.
    For starters, I am using a simple RC low pass filter with values of R=1kΩ and C=1μF. The transfer function will be:
    (1/RC)/(s+(1/RC)) or 1000/(s+1000).
    The commands I am using are:
    num=[1000];
    den=[1 1000];
    Hs=tf(num,den);
    ImpRes=impulse(Hs);
    MagFFT=abs(fft(ImpRes));
    plot(MagFFT);
    I am confident up until the plot of the magnitude of the fft. Any ideas?
  2. kdillinger
    Jul 26, 2009
    141
    109 views and no replies. :(
    I decided to skip writing my own FFT in MATLAB and use the freqs routine instead.
    An FFT will come at a later date. ;)
  3. guitarguy12387
    Apr 10, 2008
    359
    12
    I don't understand... whats the issue? Did you get an unexpected/incorrect result?
  4. kdillinger
    Jul 26, 2009
    141
    The problem is I am getting what appears to be incorrect results. I am entering a transfer function; i.e., 1000/(s+1000), getting the impulse response and then taking the FFT of that data. I am expecting the frequency response. More importantly, a frequency response as in gain & phase vs. frequency. But I am having difficulty formatting the results.
  5. guitarguy12387
    Apr 10, 2008
    359
    12
    Why don't you just plot the abs of your original transfer function? Oh also, plot on a loglog() axis
