Maths integration problem
webpower
Joined Jul 13, 2012
16
Hi this is a maths question its related to finding a charge distribution along a line.
But it boils down to solving an integral.
Now I have the solution from the text book but I can not figure out how they solved it. Can anyone on here do this integration. as follows
integral x/(x^2+y^2)^(3/2) dy = y/(x sqrt(x^2+y^2))+constant
How was that worked out? Really would appreciate any ones help on this.
It looks really simple but I have tried substitution and looked up all the ordinary qouted lists of integrals but I can't do it.
wayneh
Joined Sep 9, 2010
17,498
It's odd form but the OP's x has to be constant when you'er integrating over dy, just as "a" is constant when integrating over dx in (41). In other words, the OP's "Y" is "x" in the integral table. His "x" is "a", any constant.
MrAl
Joined Jun 17, 2014
11,489
Because the solution is already given we know that x can be treated as a constant.
We should be able to use trigonometric substitution using the substitution:
y=x*tan(A)
where A is the angle.
Try that and see if you can solve it. You might have to look up some trigonometric identities, but once done it should simplify to a very simple ratio involving one trig factor which can then be easily integrated.
