When i recorded eeg, i found that these file formats were produced(PDT and LED and VAL)No one can help you if we do not know what is LED format.
It's not hard:Would you mind providing a bit of information about what you did. It might help other people in the future.
As i said in #1,#2 posts,LED is the format of my eeg data.You did not say what is precision and what does LED stand for.
Why do you think that saying that the file is LED format is going to mean anything to anyone here? The fact that MatLab was able to open it probably means that it is an ASCII file, but that doesn't say anything about how the contents are formatted.As i said in #1,#2 posts,LED is the format of my eeg data.
Precision "contains a data type specifier such as int or float,followed by an integer giving the size in bits".It depends on ur particular eeg machine.
Getting close. I have a pretty good idea of what the format probably is, but there are some ambiguities still. Tell you what, if you could post a few lines from the file, say enough to have at least four samples from each channel, then I will write a description of what I think the format is. From that, you will see the kinds of things that it takes to properly describe a file format.Oops!
There was a big misunderstand!
Now i understand your meaning.
This file contains 24 EEG channel samples with string presicion of int16(2 bytes for each channel as i know)
Was it your question? or there are other unclear points???
I think it's an ad hoc and/or proprietary file extension.My question is, what does the file extension LED mean?
For example,
.doc = document
.lst = list
.txt = text
.bin = binary
.dll = dynamically linked library
.fig = figure
.m = meta
