Math Q. cuz I'm bored...
Discussion in 'Math' started by mbohuntr, Jun 25, 2009.
  1. mbohuntr
    Thread Starter Active Member
    Apr 6, 2009
    413
    32
    I'm trying to calculate dipole lengths, and I need the calc for wavelength. isn't it 186000(light speed)/frequency?
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    yes...but that will give you the antenna length in miles. :)
    A better rule of thumb
    1/2 wave dipole= 468/frequency(MHz)
    ERic
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Is the lag included in that number? I thought there was a 95% (or so) difference in the speed of light in a vacumn vs. a wire.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Maybe closer to 96%. The antenna should be 4% shorter (I seem to recall) than the math indicates.
  5. ELECTRONERD
    May 26, 2009
    1,146
    16
    Or you can do 300/f (in MHz), to find the distance in meters. Yes you are correct, I'm not sure what percentage it really is but we tend to use an antenna analyzer to read the SWR and impedance of the antenna and then usually clip the ends a bit to adjust it.
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    yes it is.....in free space it woud be 492 :)
    eric
  7. mbohuntr
    Apr 6, 2009
    413
    32
    Awsome! thanks!
