Math Idea
Discussion in 'Math' started by adrian.dmc, Jan 22, 2008.
  1. adrian.dmc
    Thread Starter Active Member
    Feb 22, 2007
    52
    I as studying for math and I as studying the equation |x| and I as thinking in a way to draw that function in my calculator but I didn't know how to represent |x| so I got the idea of plotting sqrt(x^2) and it worked. Later I as confronted with a function like: -1 for -1 < x < 0 and 1 for 0 < x < 1 and because |x|' its that function I derivate the function sqrt(x^2) and obtained x/sqrt(x^2) and it worked its exactly the same except that the function is not defined in x = 0.
    Is this "property" used, in my opinion I think it would be very useful for example in "heaviside" functions? Am I being stupid?
    Example:
    5 + 3 * heaveside(x-2) = 5 + 3 * ((x/sqrt(x^2) + 1)/2)
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Yes, it is known as the modulus of the number and is very widely used. None more so than in complex numbers that are widely used in many branches of electrical and electronics engineering.
    See Volume 2 - Chapter 2 for examples of how it is extensively used in electronics.
    Dave
  3. adrian.dmc
    Feb 22, 2007
    52
    I was not referring to |x| I as referring to the equivalence between |x| and sqrt(x^2) and to the "special" function provided by the derivate of that.
  4. Mark44
    Nov 26, 2007
    626
    Adrian,
    |x| = sqrt(x^2) for all real numbers x.
    d/dx (|x|) = -1 for x < 0
    = 1 for x > 0
    The absolute value function is not differentiable for x = 0, which is easy to understand because of the sharp corner at (0,0).
    The Heaviside step function is defined in a similar way, but isn't the same. It's defined in this way:
    H(x) = 0 for x < 0
    H(x) = 1 for x > 0
    To make it defined everywhere on its domain, you can set H(0) = 0.5, which is something of an arbitrary value. Doing this makes it piecewise continuous. There's no possible value of H(0) that will make the function continuous.
    Mark
  5. adrian.dmc
    Feb 22, 2007
    52
    We are right I'm wrong... (LOL) The last part of the post (the Example) is completely wrong... Sorry.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Apologies, I misinterpreted your initial question. I concur with the answer provided by Mark44.
    Dave
