Math for CMRR
Discussion in 'Math' started by jmoore313, Jul 16, 2014.
  1. jmoore313
    Jan 16, 2014
    Greetings,
    I'm working on a problem with decibel calculations for CMRR on an instrumentation amplifier. The formula is straightforward:
    CMRR = 20 log (Av(d) / Av(cm)). I've been given a CMRR of 130dB and I have a measured Av(d) (differential gain) of 46.15 and I'm trying to solve for Av(cm) -(common mode gain). I've been told that the ratio for a CMRR of 130dB should be 3.16 * 10 (6).
    Just having a little trouble figuring out how to make my TI-83 do this. Any help would be appreciated.
    Thanks.
  2. djsfantasi
    Apr 11, 2010
    2,899
    870
    Do some manual work on the equation to isolate the variable you are looking for. Then, the calculator operations will become obvious.
    Sol'n
    CMRR=20 log( Av(d) / Av(cm) )
    130/20=log( 46.15/Av(cm) )
    10^6.5=46.15/Av(cm)
    Av(cm)=46.15/10^6.5
  3. jmoore313
    Jan 16, 2014
    Thank you so much for your help.
