Question: S-matrix of a transistor is given (for a reference impedance \(Z_0 = 50 Ohm\)). Transistor is unilateral (\(S_{12} = 0\)). Obtain matching networks (source and load) for maximum transducer gain when both source and load have impedances of \(100 Ohm\).
My approach: Since the device is unilateral, the gain is maximum if both gains of input and output matching networks are maximum as well, i. e., \(p_s=(S_{11})*=p_{in}*\) and \(p_L=(S_{22})*=p_{out}*\).
In the design of the networks I don't have problems. My doubt is about the impedances of \(100 Ohm\) since the S-matrix given is for \(Z_0 = 50 Ohm\).
a) Should I design as I described above considering the ports with \(100 Ohm\) (usually is for \(50 Ohm\))?
b) Or before any design I need to re-normalize the S-matrix given to \(Z_0= 100 Ohm\)?
Regards.
Regards.
