matching capacitors
Discussion in 'General Electronics Chat' started by abNORMal, Mar 21, 2009.
  1. abNORMal
    Mar 21, 2009
    Hi All. Noob here. No particular electronics background (as you'll see), just a hobbyist.
    I have a subwoofer that was doing nothing but cracking/popping, so I opened it up and found 3 leaking capacitors. I'm trying to buy replacements, but I don't know a damn thing about this, so I come to you.
    The ones I ID'd are:
    10 uf 35 volt 105 degree 11mm high
    100 uf 16 volt 105 degree 11mm high
    2200 uf 200 volt 105 degree vented 45m high
    Questions are:
    The first 2 I can find what appear to be matches for on this site
    but I can't seem to match up the third one.
    How close do I have to be? I can find one that has the right numbers, but it's not vented. It's also shorter and the pins seem to be a little closer. Ones listed are 10mm apart. Mine are more like 12 mm apart.
    This one seems closer, but there's no image:
    So, if the capacitance, voltage and temp match, it that good enough?
  2. flat5
    Nov 13, 2008
  3. abNORMal
    Mar 21, 2009
    Hi flat5
    If that image is at all accurate, I don't think it'll do. It also lists the temp at 85 d, so that also doesn't match, but I don't know how critical that is.
    btw I meant the last link. The SLP222M100C4P3 looks like more of a match
  4. Audioguru
    Dec 20, 2007
    The capacitors in a speaker crossover operate with AC, not DC. So they must be non-polar.
    The capacitors you found are polarized for operating only on DC so they will blow up if used with the AC signal of a speaker.
    Digikey used to sell non-polar electrolytic capacitors.
  5. abNORMal
    Mar 21, 2009
    Thanks. This is the stuff I need to know. Thinking on this a bit, it isn't really a crossover. It's a powered subwoofer. There's only one speaker.
    What is polarized/non-polarized? These look like run of the mill cans with a stripe on one side. I thought that indicated polarity.
