I'm trying to match the output of an audio amplifier to an 8ohm speaker but I don't have a transformer. I can't find them anywhere. Can I match impedance with a capacitor network? How can I do this?
Sixty years ago, vacuum tube amplifiers used an output transformer to match the high output impedance of the vacuum tubes to the low speaker impedance.
But modern transistor amplifiers have an extremely low output impedance so a transformer is not needed.
Modern amplifiers do not "match" the speaker impedance. The extremely low output impedance provides excellent damping of resonances in a speaker.
Yea, like the one you posted studioT accept I don't have one of those. The circuit works and I can hear audio from the speaker but the volume is low. I tried it once before with the transformer and the sound increased but now I don't have that transformer and want to figure out another way to do it. Something like http://www.hoflink.com/~mkozma/match19c.html is what i was looking at but the site doesn't work for me. Its running off a battery so I can't just up the voltage cause its at its max now.
Is your amplifier lacking gain or is it lacking enough output power before clipping?
The gain of an amplifier can be increased by increasing the value of one resistor, not by adding an output transformer.
An audio amplifier is designed for a certain speaker impedance, usually 8 ohms.
Some amplifiers produce more output power into 4 ohms and 2 ohms.
A transformer might transform an 8 ohm speaker into 2 ohms so the amplifier has more output power (if it doesn't blow up).
Please attach the schematic of your amplifier with its parts list.
I am with audio Guru....the output of your amplifier may not have enough gain to crank the speaker. What type of speakers are you driving and how many of them do you have? Please send a schematic so we can check out your application.
A single-ended amplifier like an LM386 has an output at clipping into 8 ohms with a 6V supply of only 0.2W.
But a TDA2822M amp IC is two amplifiers that are bridged and drive both wires of the speaker with over double the voltage swing of the LM386 and it doesn't need the huge output coupling capacitor of the LM386 circuit. Its output at clipping into 8 ohms with a 6V supply is 1.1W.
