Matching amplifier and speaker
KJ6EAD
Joined Apr 30, 2011
1,581
The conventional wisdom would say anything greater than 50W. There are two complications though: one, the amplifier rating may be exaggerated by the manufacturer and two, it's best to have plenty of headroom in the speaker so the amplifier can never damage it.
Speakers are sometimes overrated by their manufacturers as well, so for efficient power handling without distortion my advice would be to use a speaker rated for 100W.
Spence
Joined Apr 23, 2010
49
4 Ohm is the minimum recommended impedance, there's no need to put 2 8 Ohm speakers in parallel.
Almost all amplifiers in the range of 10 to 100 watts are comfortable with a 50 watt speaker but you shouldn't overdrive an amplifier because that's when the output gets dirty and dangerous. If you have to turn an amplifier above halfway on the volume, then you really need a bigger better amplifier.
What make or type of amplifier is it?
kubeek
Joined Sep 20, 2005
5,795
Other problem is, that the amp is usually capable of putting say 100W into 4ohm load, but it will probably achieve less than 50W into 8ohm, so paralleling the speakers is not a bad idea. I usually like to use the lowest recommended impedance available.
