Master Slave Clocks with PIC16F887
Discussion in 'Programmer's Corner' started by RRITESH KAKKAR, Mar 31, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I have pic16f887 and i want to connect the RTC module with it, Module from provotech, it has scl and sda.
    according to little research it say to connect the SQW to timer interput at 1Hz something like that!!
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    "scl" and "sda" sounds like the I2C bus, known as the MASTER SYNCHRONOUS SERIAL PORT (MSSP)MODULE and lives on pins 23 (SDA) and 24 (SCL).
    To receive an interrupt signal tie it to a suitable pin such as pin 33 (INT).
    I would also say a bit more research is required.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The data sheet says....
    00 to 007h mean display register!
    But what about 08h to 3fH mean here?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It means that there are 56 bytes of RAM at location 08h to 03Fh. That statement was just about as clear as it could be. What did you think it meant?
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Need of it where to use it?
    and after that how to work with DS1307 to get time and dates?
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That's up to you. It's just another resource, you can use it or ignore it.
    The time and dates are in the datasheet
    RRITESH KAKKAR likes this.
  7. shteii01
    Feb 19, 2010
    3,500
    511
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I will use 7 segment LED display..
    only min and hours.
    so, how to start in Hi tech c i have done i2C based project in BLDC ESC motor.
    thanks
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How to use PIC16F887 AS DIGITAL INPUT OUT ?
    What is this?
    PBADEN = 0ff
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What does the datasheet say?
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    It is done by Ian
    The pic18 has the PBADEN.... On the pic16 you need to use " ANSELH = 0;"
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Here is code i have updated how to read I2C function is not present, how to read from DS1307
    Code (C):
    1. #include <htc.h>
    2. __CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
    3. #define _XTAL_FREQ 20000000
    4. #define SDATA RC4
    5. #define SCLK RC3
    6. void I2C_init(),I2C_start(void),I2C_write(char x), I2cSTOP(void);
    7. void i2c_Wait(void);
    8. char data[13]={  0b00010000,0b01111101,0b00100011,0b00101000,0b01001101,0b10001000,
    9. 0b10000000, 0b00111101,0X00,0b00001000};
    10. void main(void){
    11. ANSELH = 0;
    12.     TRISC3=1; //direction to input have be changed
    13.     TRISC4=1;
    14. unsigned char ch=0;
    15. TRISC0=0;
    16. TRISB=0X00;
    17. TRISD=0X00;
    18. TRISC1=0;
    19. TRISC2=0;
    20. RC0=0;
    21. RC1=0;
    22. RC2=0;
    23. __delay_ms(500);
    24.     I2C_init();
    25. __delay_ms(50);
    26.
    27.     I2C_start();
    28.     I2C_write(0xd0);//  DS1307 addr
    29.
    30. I2C_write(0x00);//    ds1307 addr
    31. I2C_write(0x01);//   writing 1 sec
    32. I2cSTOP();
    33. while(1){
    34.     I2C_start();
    35.     I2C_write(0xd0);//  DS1307 addr
    36.     I2C_write(0x00);//ds1307 addr
    37.     I2C_start();
    38.     I2C_write(0xd1);//DS1307 addr bit high for reading
    39.     ch = I2C_Read();  //  how to read it??
    40.
    41. I2cSTOP();
    42. RD0=0;
    43. RD1=0;
    44. RD2=0;
    45. RD3=1;
    46. PORTB=data[ch];
    47. __delay_ms(500);
    48. PORTB=0B00000000;
    49.
    50.
    51.
    52.
    53. }
    54. }
    55. void I2C_init(void)
    56.     {
    57.   SSPCON = 0x38;      // set I2C master mode
    58. SSPCON2 = 0x00;
    59. SSPADD = 0x0C;  //400KHZ  20MHz xtal
    60. SSPSTAT|=0X80;
    61. PSPIF=0;      // clear SSPIF interrupt flag
    62. BCLIF=0;      // clear bus collision flag
    63. }
    64. void I2C_start(void)
    65. {
    66.     i2c_Wait();
    67.     SEN=1;
    68. }
    69. void I2C_write(char x){
    70.     i2c_Wait();
    71. SSPBUF=x;
    72.         }
    73. void i2c_Wait(void){
    74.     while((SSPCON2 & 0X1F || (SSPSTAT & 0X04)));
    75. }
    76. void I2cSTOP(void)
    77. {
    78.     i2c_Wait();
    79.     PEN=1;
    80. }
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Now i am understand the working of start and stop now i want to learn addr and read process!
  14. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    here is code of it for pic but incomplete..
    Code (C):
    1. http://www.8051projects.net/wiki/DS1307_I2C_RTC_Interfacing_Tutorial
  15. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have modified the code simple version.
    please have a look i have write 0x0f in sec register @ 0x00h addr to watch the change after this i am reading the i2c buffer register to get value!
    In MPLAB build successful, hanging at in debugger can we test code in this?
    Code (C):
    1. #include <htc.h>
    2.
    3. __CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
    4. #define _XTAL_FREQ 20000000
    5. #define SDATA RC4
    6. #define SCLK RC3
    7. void I2C_init(),I2C_start(void),I2C_write(char x), I2cSTOP(void);
    8. void i2c_Wait(void);
    9. char data[13]={  0b00010000,0b01111101,0b00100011,0b00101000,0b01001101,0b10001000,
    10. 0b10000000, 0b00111101,0X00,0b00001000};
    11.
    12. void main(void){
    13. ANSELH = 0;
    14.     TRISC3=1; //direction to input have be changed
    15.     TRISC4=1;
    16. unsigned char ch=0;
    17.     unsigned char i;
    18. TRISC0=0;
    19. TRISB=0X00;
    20. TRISD=0X00;
    21. TRISC1=0;
    22. TRISC2=0;
    23. RC0=0;
    24. RC1=0;
    25. RC2=0;
    26. //__delay_ms(500);
    27.     I2C_init();
    28. //__delay_ms(50);
    29.
    30.     I2C_start();
    31.     I2C_write(0xd0);
    32.
    33. I2C_write(0x00);
    34. I2C_write(0x0f);
    35.
    36.
    37. I2cSTOP();
    38.
    39. while(1){
    40.     I2C_start();
    41.     I2C_write(0xd0);
    42.     I2C_write(0x00);
    43.     I2cSTOP();
    44.     I2C_start();
    45.     I2C_write(0xD1);
    46.    i= SSPBUF;
    47.
    48.     I2cSTOP();
    49. }
    50.
    51.
    52. RD0=0;
    53. RD1=0;
    54. RD2=0;
    55. RD3=1;
    56. PORTB=data[i];
    57. __delay_ms(500);
    58. PORTB=0B00000000;
    59.
    60.
    61. }
    62.
    63. void I2C_init(void)
    64.     {
    65.   SSPCON = 0x38;      // set I2C master mode
    66. SSPCON2 = 0x00;
    67. SSPADD = 0x0C;  //400KHZ  20MHz xtal
    68. SSPSTAT|=0X80;
    69. PSPIF=0;      // clear SSPIF interrupt flag
    70. BCLIF=0;      // clear bus collision flag
    71. }
    72. void I2C_start(void)
    73. {
    74.     i2c_Wait();
    75.     SEN=1;
    76. }
    77. void I2C_write(char x){
    78.     i2c_Wait();
    79. SSPBUF=x;
    80.         }
    81. void i2c_Wait(void){
    82.     while((SSPCON2 & 0X1F || (SSPSTAT & 0X04)));
    83. }
    84. void I2cSTOP(void)
    85. {
    86.     i2c_Wait();
    87.     PEN=1;
    88. }
    89.
    90.
    91.
    92.
    93.
    94.
    95.
    96.
    97.
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Can any one help me about I2C with DS1307?
  17. shteii01
    Feb 19, 2010
    3,500
    511
    I2C_write(0xd0);
    Is this where you get an error?
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Here is the codei want only min and hours but not working display and | | on segment!
    Code (C):
    1. #include <htc.h>
    2.
    6. #define SCLK RC3
    11.
    13. ANSELH = 0;
    15.     TRISC4=1;
    17. unsigned char i=0;
    18.
    19. TRISB=0X00;
    20. TRISD=0X00;
    21. PORTB=0B00000000;
    22. __delay_ms(500);
    23.     I2C_init();
    24. __delay_ms(50);
    25.
    26.     I2C_start();
    27.     I2C_write(0xd0);
    28.
    29. I2C_write(0x00);
    30. I2C_write(0x02);
    31.
    32. I2cSTOP();
    33.
    34. RD0=0;
    35. RD1=0;
    36. RD2=1;
    37. RD3=0;
    38.
    39. PORTB=data[5];
    40. __delay_ms(800);
    41. PORTB=0B00000000;
    42.
    43. RD0=0;
    44. RD1=0;
    45. RD2=0;
    46. RD3=0;
    47.
    48.     I2C_start();
    49.     I2C_write(0xd0);
    50.     I2C_write(0x00);
    51.
    52.     I2cSTOP();
    53. while(1){
    54.     I2C_start();
    55.     I2C_write(0xD1);
    56.    i= SSPBUF;
    57.
    58.     I2cSTOP();
    59.
    60.
    61. RD0=1;
    62. RD1=0;
    63. RD2=0;
    64. RD3=0;
    65. PORTB=data[i%16];
    66.
    67. __delay_ms(500);
    68. PORTB=0x00;
    69.
    70. RD0=0;
    71. RD1=1;
    72. RD2=0;
    73. RD3=0;
    74. PORTB=data[i>>4];
    75.
    76. __delay_ms(500);
    77. PORTB=0x00;
    78.
    79.
    80.
    81.
    82. }
    83. }
    84. void I2C_init(void)
    85.     {
    86.   SSPCON = 0x38;      // set I2C master mode
    87. SSPCON2 = 0x00;
    88. SSPADD = 0x0C;  //400KHZ  20MHz xtal
    89. SSPSTAT|=0X80;
    90. PSPIF=0;      // clear SSPIF interrupt flag
    91. BCLIF=0;      // clear bus collision flag
    92. }
    93. void I2C_start(void)
    94. {
    95.     i2c_Wait();
    96.     SEN=1;
    97. }
    98. void I2C_write(char x){
    99.     i2c_Wait();
    100. SSPBUF=x;
    101.         }
    102. void i2c_Wait(void){
    103.     while((SSPCON2 & 0X1F || (SSPSTAT & 0X04)));
    104. }
    105. void I2cSTOP(void)
    106. {
    107.     i2c_Wait();
    108.     PEN=1;
    109. }
    110.
    111.
    112.
    113.
    114.
    115.
    116.
    117.
    118.
  19. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    In this setting will ds1307 will work fine?
    Code (C):
    1. void I2C_init(void)
    2.     {
    3.   SSPCON = 0x38;      // set I2C master mode
    4. SSPCON2 = 0x00;
    5. SSPADD = 0x0C;  //400KHZ  20MHz xtal
    6. SSPSTAT|=0X80;
    7. PSPIF=0;      // clear SSPIF interrupt flag
    8. BCLIF=0;      // clear bus collision flag
    9. }
    10.
