Hello people
here is my question I am lighting 170 high bright red leds 100 of them must be slightly dimmer than the others currently they are wired in 5 series to parallel = 20 legs with 150 ohm resistors and 14 legs with 1k ohm resistors as you can see thats a lot of resistors can this be slimmed down using constant current driver? my board space is limited to the leds so making a constant current driver board seems like the best way to reduce the space requirements
