MARIE ASSEMBLY PROGRAM to sort integer values
Discussion in 'Homework Help' started by dba mcitp, Nov 16, 2014.
  1. dba mcitp
    Nov 15, 2014
    You are to write an assembly language program for the MARIE ISA. The program will sort an array of integers in ascending order.
    The general structure of the assembly language source code is illustrated in figure 1. Note that your code will precede the data area.
    ORG 100
    /Your program goes here
    HALT
    Addr, HEX 200 /Address of 1st array elements
    N, DEC 6 /Number of array elements
    DEC 18 /First Value
    DEC -3
    DEC 10
    DEC 1
    DEC -3
    DEC 0
  2. djsfantasi
    Apr 11, 2010
    2,900
    874
    And? Is there a question there?
    The way Homework Help works is that you explain the problem, then show your work and tell us what's not working or where you are stuck
    So can you show your program thus far?
