MARIE assembly language
Discussion in 'Programmer's Corner' started by m8763, Feb 5, 2009.
  1. m8763
    Dec 2, 2008
    6
    How can I write this code segment in MARIE?
    if x>1 then
    y= x+x;
    x=0;
    endif;
    y=y+1;
  2. m8763
    Dec 2, 2008
    6
    The following is what I came up with as an answer.
    Load x
    Subt one
    Skipcond 800
    Jump Next
    Load x
    Add x
    Store y
    Clear
    Store x
    Load y
    Add one
    Store y
    Next, Halt
    x, dec 20
    y, dec 10
    one, dec 1
    Can anyone correct my mistakes, if any, please?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In my very limited knowledge of assemblers, MARIE is absolutely new. My experience with assembly language is that you have to be fully conversant with the processor and its instruction set in order to write code. The assembler imposes constraints as to syntax acceptable to itself, but has very little to do with the actual functioning of the code.
    Your directives would never get parsed correctly by any assembler I have used, but I don't have any knowledge of MARIE. It is otherwise conventional to begin with an ORG statement to tell the assembler where the code block is to start. One follows with directives that EQUate labels to fixed addresses, and so on.
  4. atferrari
    Jan 6, 2004
    2,666
    784
    Is it MARIE currently in use? What micros?
    Hi BT,
    The OP seems to be asking about syntax only, isn't it?
  5. m8763
    Dec 2, 2008
    6
    This is the best solution with comments:
    If, Load X / Load X
    Subt One / Subtract 1, store result in AC
    Skipcond 800 / If AC>0 (X>1), skip the next instruction
    Jump Endif / Jump to Endif if X is not greater than 1
    Then, Load X / Reload X so it can be doubled
    Add X / Double X
    Store Y / Y= X + X
    Load Zero / Move 0 into AC
    Store X / Set X to 0
    Endif, Load Y / Load Y into AC
    Add One / Add 1 to Y
    Store Y / Y = Y + 1
    Halt / Terminate program
    X, Dec ? / X has starting value, not given in problem
    Y, Dec ? / Y has starting value, not given in problem
    One, Dec 1 / Use as a constant
    Zero, Dec 0 / Use as a constant
  6. RiJoRI
    Aug 15, 2007
    536
    26
    Found on Giggle:
    Training wheels?
    And for the OP, look up MarieSim, and put your code through that.
    --Rich
  7. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
