Marantz 1150 D phono hum issue
Discussion in 'The Projects Forum' started by Meerkat 67, Aug 17, 2015.
  1. Meerkat 67
    Jan 29, 2015
    21
    I recently acquired a Marantz 1150D integrated amp that has a hum on the phono inputs only..I have cleaned all controls and checked for poor grounds etc but nothing.. Anyone have the same problem and can steer me in the right direction.? \I do not know if this amp is rare but my son was going to recycle it just beforeI took it Cheers Wayne
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
    Is the hum there with the phono inputs shorted to ground?
  3. Kermit2
    Feb 5, 2010
    3,847
    963
    Every time I have encountered audio 'hum' problems it has always been due to a grounding issue with the source audio(phonograph in your case) or the amp.
    nsaspook likes this.
  4. Meerkat 67
    Jan 29, 2015
    21
    I have tried the phono shorting plugs and the hum is still there... The issue, at least from what I can see, is that the problem would be in the preamp board area.. I do not have a service manual, but will try to get one to proceed. As I said I am not familiar with this Marantz Model..At this point the only issue is the phono circuit, all other inputs are fine and hum free. Once I get a schematic/service manual, this will help..
    Thanks for the replies and if anyone else had a similar issue let me know...
    Cheers... Wayne
  5. Dodgydave
    Jun 22, 2012
    5,143
    768
