Many 1 Bit DRAM to Fewer 4 Bit?
Discussion in 'The Projects Forum' started by apprenticemart2, Aug 5, 2014.
  1. apprenticemart2
    May 7, 2013
    67
    7
    I have a system that uses 256 x 1 DRAM (12 of them to give 12 bits)
    The system supports up to 1M total with 4 x ROW ADDRESS STROBES, 1 strobe for each 256K x 12 bank
    and I want to try and build a memory expansion board using 256 x 4 DRAM to save on chip count.
    The 256 x 4 has an OUTPUT ENABLE that the 256 x 1 doesn't.
    How would I generate this, using an inverter on the WRITE ENABLE so that when WRITE ENABLE is 1 OUTPUT ENABLE is 0 and vice versa?
    Any tips on using 4 bit DRAM instead of 1 bit?
    I could also try to use larger 1 Bit DRAM like 1M x 1?
    (I would only be using 768K of the whole 1M)
    How would I use the extra ROW ACCESS STROBES to control the extra address lines if this is how I would do it?
    No I don't really know what I'm doing. I'm stubborn like that :)
    Any help is better than none.
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    Do you have the circuit or block diagram?
    The type of DRAM?
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Very confusing writeup, its not clear why you need or want to use DRAM, and if you use it, dont you know they need refresh, and lets say you cater for that, but now you are some how stuck how to use a different DRAM chip?
    Or do you want to rebuld/repair an old circuit?
  4. apprenticemart2
    May 7, 2013
    67
    7
    I want to make an addition to a circuit I already have.
    I have no knowledge of anything other than to try to copy the mechanisms that the device already uses in attempt to understand how it works.
    I have a schematic for a memory expansion card that I already have which gives me 512K total. I want to learn how I can upgrade this to 1Mb.
    There is 256K on the mainboard, and 256K on the expansion card.
    If there are better ways to do it than to try to copy the original design then I would be interested to know.
  5. takao21203
    Apr 28, 2012
    3,578
    463
    as far as I understand in the circuit Q and D are simply connected, while most memory chips only have IO, and use /OE to enable the output for reading, otherwise put the data on the databus, and dont enable.
    I think in the schematic its /W, which you'd have to connect to /OE.
    And dont forget /CS too, there could be one or two.
    Anyway, 256 bits is very small these days, you could replace it with static RAM probably.
    And in the schematic there are 9 address lines.
    12bit width is odd too.
  6. apprenticemart2
    May 7, 2013
    67
    7
    Thanks. I'll keep researching.
  7. takao21203
    Apr 28, 2012
    3,578
    463
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Many DRAM controllers from that era (256 x 1) were made from MSI logic. You might have more than a little bit of trouble adapting such a controller to your purposes. On the other hand if there is an IC DRAM controller you might have trouble finding the part as it might be obsolete. In either case you might want to consider a new design of your own rather than trying to adapt someone else's design.
    Tell us what you know from the chips you see on the existing board.
  9. apprenticemart2
    May 7, 2013
    67
    7
    Yes. This was the second option in my original post.
    It may be easier as the 1M x 1Bit chips will use the same signals as the 256 x 1Bit chips. The only difference is that there are more address spaces than the 256k chips. I would tie the unused addresses to +V?
    So, would I just connect the extra ROW Address Strobes up to the extra addresses directly or would some signal conditioning/alteration be required before hand?
    I'm reading these at the moment
    http://n8vem-sbc.pbworks.com/f/SRAM+Replacement+for+TMS99x8+VRAM.pdf
    http://bitcycle.org/retro/spectrum/SRAM_replacement/
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The verbal descriptions are getting way too confusing. I suggest a schematic of the existing board and your proposed schematic of the replacement board.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Replacing DRAM with SRAM will work if you want to eliminate the controller and the multiplexing altogether. We can't hep very much without a schematic because we CANNOT see what you are working with!!
  12. apprenticemart2
    May 7, 2013
    67
    7
    OK. In that case I have to use DRAM. The signals I have to work with are the same ones that the expansion board uses that I already posted so I'm just going to have to duplicate the ram expansion board another 2 times and stack them on top of each other.
    I found an old website that used to have a schematic of a board that could be used to replace 4off 256x1bit dram with 1off 256x4bit dram but the site has been abandoned and the download link doesn't work. 24 extra chips is a lot. I would like to cut down on that by using 4 bit chips but they have an output enable signal which is in addition to all the signals the 1 bit drams have.
    Thanks for your help.
    The ram expansion board connects to the connector P205 I have marked with a sticky in the PDF comments and the data lines are up in the top right corner.
  13. apprenticemart2
    May 7, 2013
    67
    7
    CPU section
    • CPU.pdf
      File size:
      440 KB
      10
  14. apprenticemart2
    May 7, 2013
    67
    7
    If anyone knows how I can replace 4 one bit DRAM chips with one 4 bit DRAM chip that would be great. Thanks. That was my original question.
  15. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm still working my way through the schematics, and I'm going on vacation tomorrow so you'll just have to be patient.
  16. apprenticemart2
    May 7, 2013
    67
    7
    Sorry was just updating it in case anyone got confused as to what the mission objectives were :)
    Have a nice vacation and don't bring any Ebola back with you.
  17. Papabravo
    Feb 24, 2006
    10,340
    1,850
    AFAIK there are no cases in northern Michigan.
