Manual Reset IC
Discussion in 'General Electronics Chat' started by crazyengineer, Sep 20, 2013.
  1. crazyengineer
    Dec 29, 2010
    156
    Hello everyone. I'm looking for an IC in which when I apply 5v to it, the chip's output will go open drain for 15s-20s. I tried looking at watchdog timers, but they require pulses for it to time out. Does anyone have any suggestions on IC's that can do this?
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    Why not just a transistor or mosfet?
  3. crazyengineer
    Dec 29, 2010
    156
    I would use a mosfet, but I'm afraid I will have limited space to work with.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    You are looking for something smaller than a single transistor? That will be difficult. How small do you need this to be?
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    You need a power-on reset circuit, something like a MAX823, MAX824, MAX825
    15-20 seconds is unusually long.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    Bigger than a transistor/mosfet though.. So if thats truly a requirement then he is out of luck..
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Mitsubishi used to do power on reset chips - I think their semiconductor division became part of Renaiaance along with that of Hitachi.
  8. ErnieM
    Apr 24, 2011
    7,435
    1,625
    You are looking for what's called a power supervisor. They are ubiquitous and packages in 3 lead transistor packages (sorry, all I see are SMD so they are incredibly tiny.
    Linkie
  9. ian field
    Oct 27, 2012
    4,447
    791
    Some PC ATX PSUs have a dedicated chip for the power good line, but I can't remember if they're the same thing or not.
    Even recently, I've found 5-pin SIL types as opposed to microscopic SMD.
