Manual DAC - help calculate resistors?
Discussion in 'General Electronics Chat' started by TheComet, Nov 13, 2013.
  1. TheComet
    Mar 11, 2013
    88
    12
    Problem
    The schematic can be viewed here: http://imgwiz.com/images/2013/11/13/1fqrc.png
    I require a digitally adjustable sine-wave generator in the range of 100kHz-10MHz. The frequency is set by "switching" in and out 8 different resistors using analog switches.
    I'm having trouble calculating the resistors because
    1. The frequency needs to be adjusted logarithmically and not linearly. This is so the frequency steps are appropriately scaled to the magnitude of the frequency and appear even (more information about that in the "graphs" section)
    2. The resistors aren't in series, they're in parallel. This is to minimize tolerances of the resistors and analog switches, but it makes calculating them far more difficult.
    So that's what I need help with: Figuring out the values of all 8 resistors with the following constraints.
    Some Math
    Given the 8 resistors, this allows 256 steps. The frequency needs to follow the curve:
    f=f(x)=fmin*m^{x} with 0\leq x\leq 256
    where:
    m=\sqrt[n]{\frac{fmax}{fmin}}
    n = 8 (because we're using 8 bits)
    fmin = 100kHz
    fmax = 10MHz
    The frequency of the wien-oscillator can be calculated with the usual formula:
    f0=\frac{1}{2\pi RC}
    Schematic
    I've boxed the resistors that end up being parallel with each other.
    The core of the oscillator is a wien-bridge-oscillator. For simplicities sake, assume that's all it is (there's some feedback circuitry for high precision waveform and amplitude adjustment but has nothing to do with this problem).
    Graphs
    I've generated some graphs with what it currently looks like, and what I want it to look like.
    This is what it currently looks like.
    This is what I want it to look like. I used the formulas I specified above to generate the graphs below.
    The resistance is the total resistance. How do I now go about splitting up the 256 values seen in the last graph into 8 separate resistor values which can be switched in and out by the analog switches?
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    ooh! That's a tough one.
    I don't think you can do this by switching resistors.
    The only solution I can think of is to use a microcontroller.
    Create a lookup table with 256 entries. The value in each entry will be a number that controls the frequency of your sinewave using a timer module.
  3. TheComet
    Mar 11, 2013
    88
    12
    Sure it's possible with resistors, I'm just caught up on the math because they're parallel, and it involves 8 unknown values and a total of 256 equations... (as far as I can see)
    A micro controller manually generating a sine wave at 10 MHz? I don't see that happening, most micro controllers aren't clocked much higher than 40 MHz. Producing a pure sine wave at those frequencies would be impossible, that's why I'm working with an external oscillator.
    My circuit already is controlled by a micro controller (as can bee seen by the /SYNC, SCLK, and DIN pins on N1).
    Was my post unclear? Do I need to re-formulate my question?
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    Why not use a voltage controlled oscillator and output the control voltage from a DAC?
  5. kubeek
    Sep 20, 2005
    4,691
    806
    I don´t think that the fact they are in parallel matters, because you can look at the resistors as conductances that simply add up, then inverse the value to get total resistance.
    Now let´s get started on the math. If you got 8 variables, you need 8 equations to solve for all of them. Now if you got 256 of these equations, unless the rest of them are are "equivalent" to the 8(..to a linear combination of remaining 8) they will contradict any other solution you find.
    Linearity is the key here, 8bit linear DAC works just because all the steps are linear.
    Thus I pronounce this a dead case, but I´m ready to be proven wrong ;)
  6. TheComet
    Mar 11, 2013
    88
    12
    The oscillator needs to have extremely low distortion (<0.01% THD) and simultaneously span a huge frequency range (factor 100). No other oscillator comes into question.
    [EDIT]
    I almost feared this would be the case; I'm beginning to agree with you the more crunch the numbers. I suppose I can approximate the curve as much as possible...
  7. MrChips
    Oct 2, 2009
    12,652
    3,461
    I believe I said back in post #2 that you cannot do this by switching resistors.
  8. ScottWang
    Aug 23, 2012
    4,934
    777
    If we using the pure hardware to convert Digital To Analog, and calcalting the Frequency and the numbers of dots of waveform:
    1Mhz clock and 8 dots of waveform : 1000000/8 = 125Khz
    1Mhz clock and 16 dots of waveform : 1000000/8 = 62.5Khz
    1Mhz clock and 32 dots of waveform : 1000000/8 = 31.25Khz
    1Mhz clock and 64 dots of waveform : 1000000/8 = 15.625Khz
    1Mhz clock and 128 dots of waveform : 1000000/8 = 7.8125Khz
    1Mhz clock and 256 dots of waveform : 1000000/8 = 3.90625Khz
    10Mhz clock and 8 dots of waveform : 1000000/8 = 1.25Mhz
    10Mhz clock and 16 dots of waveform : 1000000/8 = 625Khz
    10Mhz clock and 32 dots of waveform : 1000000/8 = 312.5Khz
    10Mhz clock and 64 dots of waveform : 1000000/8 = 156.25Khz
    10Mhz clock and 128 dots of waveform : 1000000/8 = 78.125Khz
    10Mhz clock and 256 dots of waveform : 1000000/8 = 39.0625Khz
    40Mhz clock and 8 dots of waveform : 1000000/8 = 5Mhz
    40Mhz clock and 16 dots of waveform : 1000000/8 = 2.5Mhz
    40Mhz clock and 32 dots of waveform : 1000000/8 = 1.25Mhz
    40Mhz clock and 64 dots of waveform : 1000000/8 = 625Khz
    40Mhz clock and 128 dots of waveform : 1000000/8 = 312.5Khz
    40Mhz clock and 256 dots of waveform : 1000000/8 = 156.25Khz
  9. TheComet
    Mar 11, 2013
    88
    12
    Yes, you did, but you neglected to provide any explanation as to why it's not possible. Saying it's "not possible" isn't entirely correct, because it's obviously possible if the frequency is scaled linearly (as proven in the first and second graph I posted in OP). As kubeek pointed out, a logarithmic frequency scale can't be achieved.
    I'm sorry if I appear a little frustrated, I didn't mean to attack you. This project is kind of under pressure, and I simply wanted some answers.
    @ScottWang
    The problem with this is your output waveform is going to have a very high THD (I need +80dB attenuation between harmonics), because it will look something like the following.
  10. ScottWang
    Aug 23, 2012
    4,934
    777
    It just let you to see how high the frequency that you can reach, the output waveform will be rough as saw that if the dot are too less, if you want to make it more smoothly, then you can using the RC integration circuit to modify the waveform.
    But if the waveform needs more smoothly then the dot will be need more and the output frequency will be more lower.
  11. crutschow
    Mar 14, 2008
    13,516
    3,386
    You might consider a dual logarithmic digital pot. They don't have good absolute resistance tolerance but two on the same chip might be reasonably well matched.
  12. TheComet
    Mar 11, 2013
    88
    12
    That's a good idea.
    I can't seem to find any ICs that would be capable of:
    • 56Ω - 5.6kΩ
    • Resistive response up to 10 MHz
    Do you have any recommendations?
  13. kubeek
    Sep 20, 2005
    4,691
    806
    how about changing the rest of the components to match the pot that you have available?
  14. TheComet
    Mar 11, 2013
    88
    12
    The frequency needs to be adjustable from 100kHz to 10MHz. That's a factor of 100. Since the resistance has inverse linearity to the frequency, the pot will always be required to change with a factor of 100 as well, regardless of how I adjust the other components.
  15. GopherT
    Nov 23, 2012
    6,330
    4,072
    Are you planning to sweep that frequency range or just sit on one frequency in the range. If sitting on one, then you can have a selector switch to pick a capacitor for a narrow range and allow the pot to cover a 10x range. Or, a picrocontroller can use a multiplexer or bilateral switch to select the correct capacitor for your desired frequency range.
  16. crutschow
    Mar 14, 2008
    13,516
    3,386
    The best I found in a cursory Google search is this from Analog Devices. It's a dual digital controlled resistor with 1024 steps, available with 25kΩ maximum resistance. You could perhaps use that to generate a coarse 256 step (or shorter) approximation of a logarithmic sequence by proper selection of the step size. Note that one limitation is that the resistor voltage must stay within the power supply range of 0V to 5.5V.
  17. WBahn
    Mar 31, 2012
    18,093
    4,918
    So you have 256 equations and 8 unknowns.
    Are you SURE a solution exists?
    Usually as soon as you have one more equation than unknown you have the possibility that no solution exists. Here you have that in spades.
    So unless the bulk of your equations are redundant....
