ok guys, i've been struggling with this for two days, and i think i need some help. I am trying to get a 12V LED strip to blink to the beat of my sub woofers. This is my first post on this site, and first attempt at making my own circut like this, so bear with me. This is what i have:
http://i233.photobucket.com/albums/e...chematic-1.jpg
My problem is that my subs seem to only be getting direct current. They are pushing out way farther then they usually do or if i switch the leads off the amp, they suck in. The light illuminates with the music as it should, but i'm worried about the subs and amp.
What's wrong? as simple as you can put it if you could
(just for clarification, the negative AC off the rectifier is going to the amp, and the negative DC is going to the voltage regulator.)
