Making hairs straight using static charge!
Discussion in 'The Projects Forum' started by Willen, May 10, 2016.
  1. Willen
    Nov 13, 2015
    141
    12
    Hi all,
    Many times I saw in TV that some experimenters made hairs of a people straight (floating) by charging his body which is isolated from ground. I am very interested to do the project but I do not know about it. Static charge has high volts, so I am thinking to charge body with high voltage generator like this: http://chemelec.com/Projects/Electrostatic/Electrostatic.htm
    I selected the circuit because Gary Lecomte (designer of the circuit) gifted its parts to me so that I can make this one. I even do not know I need positive or negative charge. Any mistake? Designer says it generates 6KV.
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    I doubt 6kV is enough to raise hairs significantly.
    Most of those demonstrations us a van de graaff generator - these can do 100 kV.
    shortbus likes this.
