Making digital potentiometer
Discussion in 'General Electronics Chat' started by jakovn, Jul 12, 2009.
  1. jakovn
    Jul 12, 2009
    I m trying to control 3V, 40mA laser brightess digitaly but not with PWM
    When I use analog potentiometer I get the whole rangle with 0-40 ohm resistance
    Is there a digital pot that fits requirements or something simple I could make. 16 steps is enough
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    You could use some fets that switch some resistors.
    The resistor values could be 40, 20, 10 and 5 Ohms.
    When all resistors are parallel the value will be 2.66 Ohms.
    When only the fet of the 40 Ohms is switched on the resistance will be about 40 Ohms.
    Greetings,
    Bertus
  3. millwood
    Guest
    I doubt that you will be able to find a digital pot capable of that kind of current. and low resistance digital pots are quite rare too.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Here is an example of a high-current "digital" pot:
    The original is from the National datasheet for the LM317. I am suggesting this as a concrete example of the approach suggested above by bertus, which could be adapted to mosfets.
    John
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    How about a programmable current source?
  6. ELECTRONERD
    May 26, 2009
    1,146
    16
    In your schematic example, do you simply connect the LED's to the different transistor outputs? The resistor values connected to each collector will vary the current to each output, correct? So I could have a rotary switch connected to an LED to vary the current. This doesn't seem digital at all...
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
  8. gotumal
    Mar 24, 2008
    99
    You can make use of PWM to vary the intensity continuously. Apply PWM through a suitable RC to gate of a FET. That way you can control the ID and hence the intensity of LED.
  9. millwood
    Guest
    no reason to convert the pwm back to an analog voltage through a rc network. just apply it direct to the gate so the fet stays cool.
  10. gotumal
    Mar 24, 2008
    99
    Well, it depends on application. In photometric application it would not matter since persistance of visions doesn't perceive the ON-OFF operation of LED but the average current through it.
    While in radiometric application where the constant intensity matters for few tens of microseconds, you need a very high frequency PWM. Instead, RC does this job of averaging.
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    While trying to refine the term, "digital," I stumbled on this ap. note from Analog Devices:
    It seems to be right on point for the subject of this thread.
    John
  12. ELECTRONERD
    May 26, 2009
    1,146
    16
    There we go, that looks digital to me!
