Hello there,
I want to design an H-Bridge for my application.
I learnt that I need two transistors of each type NPN and PNP to make a H-bridge in the simplest way.
here are the power transistors I am going to use
The PNP one
http://www.nex-robotics.com/product...fets/tip127-100v-5a-pnp-power-transistor.html
and the NPN
http://www.nex-robotics.com/products/electronic-components/tip122-100v-5a-npn-power-transistor.html
so my question is are those two type of transistors ideal to make a working H bridge.
What is the required voltage to drive the transistor on and off, can you drive them directly using the output from the I/O pin of an AVR (TTL) ?
It would be best if someone can refer a link related to it
The PNP one
and the NPN
