Making an FM Transmitter
Discussion in 'The Projects Forum' started by vincent19-mas, Dec 1, 2013.
  1. vincent19-mas
    Dec 27, 2012
    83
  2. MrChips
    Oct 2, 2009
    12,633
    3,453
  3. vincent19-mas
    Dec 27, 2012
    83
  4. Dodgydave
    Jun 22, 2012
    5,150
    769
    If you read the page ....
    (MIC) converts the natural sound signal into the electrical signal. The capacitor C2 is coupled to the base of transistor Q1- S9018 and whenever there is signal from the microphone, the junction capacitance of the transistor changes that contributes to change in oscillation frequency.
    Resistor R1(2.2K) is a microphone MIC bias point resistance, usually value between 2K-5. 6K is preferred, R2 provides biasing to the base of transistor. C4 and inductor L (5.5 turns coil) make up the oscillator tuning circuit, you can change the value of C4 and L to change the transmission frequency.
    Formula for frequency calculation
