Making an atom clock generator.
Discussion in 'Off-Topic' started by maxpower097, Jan 14, 2013.
  1. maxpower097
    Feb 20, 2009
    How hard would it to be to make a generator that uses the atom clock meathod of using barametric pressure changes to pump a valve that keeps the clock running forever. I don't plan on using barametric pressure for the power source something about 25 time more powerful but same effect. It will be all torque and no speed as the power source goes back and a fourth. Is their a way I can use the torque to generate more power without revolutions?
    Markd77 likes this.
  2. THE_RB
    Feb 11, 2008
    Doesn't the Atom clock use daily temperature changes to power the clock? I remember something about a really large tube filled with mercury.
    A well built mechanical clock needs only a tiny bit of power to run. How much power did you expect to get from your device?
