Making a wireless switch
Discussion in 'General Electronics Chat' started by stoopkid, Mar 8, 2013.
  1. stoopkid
    Mar 3, 2011
    136
    What would go in to making one's own very basic HIGH/LOW wireless(radio) switch? Could it be done for cheaper than tearing apart a $10 wireless doorbell or something like that? What exactly would need to go into the most basic form of this idea?
    Thanks.
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    You could make a wireless switch with an IR receiver, a transistor, and a few other components. Then you could use a junk remote control to make it switch. That's about as cheap a way as I can think of.
  3. stoopkid
    Mar 3, 2011
    136
    That would be the cheapest but I meant specifically radio switching so that I can do out of line of sight stuff.
  4. tshuck
    Oct 18, 2012
    3,531
    675
    I've seen numerous builds from a wireless doorbell, that would appear to be the cheapest.
    Unless, of course, you buy a bunch of those 433MHz, el-cheapo Tx/Rx pairs and a microcontroller to utilize them, but that's just a bunch of work;)
  5. stoopkid
    Mar 3, 2011
    136
    Say I was still motivated to try it myself, what might I want to look into to get it started?
  6. absf
    Dec 29, 2010
    1,493
    374
  7. absf
    Dec 29, 2010
    1,493
    374
    Just in case you dont like to program a PIC. There are encoders and decoders specially designed to encode and decode the RF 315/433 Mhz modules. They are PT2262 and PT2272 chips. The datasheets of these chip will tell you how to hook them up. The completed products are also available..
    http://www.escol.com.my/Sensors.html
    There are also simple kits that would operate a relay when the transmitter is pressed.. In this kits only simple chips like 4011 and LM567 are used.
    http://www.escol.com.my/kits/ES-031.html
    The above are just some examples that you can easily get by Googling. Motorola also makes the encoder and decoder chips for the remote control modules but I forgot their part numbers. Just do a search and I'm sure you can find them easily.:)
    Allen
  8. shortbus
    Sep 30, 2009
    4,096
    1,692
    $10 is pretty inexpensive, unless you are making many of these. For the $10 you are getting a item that already has been proven to work. All of the trouble shooting has been done for you, and that some times is no small part of a project.
    If you need many of these buying one and copying the circuit MAY be cheaper in the end. IF you consider your time as a zero cost.
