Making a very simple electronic door lock for pic16f84a
Discussion in 'General Electronics Chat' started by Striker235, Feb 28, 2011.
  1. Striker235
    Feb 28, 2011
    Hey, i was wondering if anyone could help me with making a simple electronic door lock in mplab.
    all im going to use is, 2 led's to display if the door is locked or not and a sensor that indicates if the door is open or not
  2. debjit625
    Apr 17, 2010
    790
    186
    MPLAB is just an IDE,which language you are using to program like MPASM(assembly) or "C".
    Thats not locking a door its just checking if the door is locked or not ,if you are trying to lock the door using some code,first you will need some sort of mechanism have you thought about it?
    EDIT :
    And yes the sensor that indicates if the door is open or not may be done with "reed switch" , I did it once but their are also many other alternatives.
    Good Luck
