Making a Synchronous counter???
Discussion in 'The Projects Forum' started by santro, Nov 30, 2009.
  1. santro
    Nov 30, 2009
    Hey could you please let me know how to design a synchronous counter on a breadboard.....thank you!!!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Well first you have to design it. Do you need some help with that part;)
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is considerable ambiguity in your request. Do you mean:
    1. How to wire up a counter IC on the breadboard?
    2. How to design a synchronous counter using transistors ?
    3. How to translate a design from a schematic into a circuit on a breadboard?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This sounds like a homework assignment by a teacher/professor/instructor.
    Is it?
  5. santro
    Nov 30, 2009
    ya it is a project in the college.........and i don't have a clue on how to start to design a counter using the breadboard......
  6. t06afre
    May 11, 2009
    5,939
    1,222
    As in every construction work, you first do your design on paper (a schematic. Then you use the the schematic to build your circuit and debug it on breadboard.
    The topic how to build a synchronous counter must be covered in your text book. Also you will find a lot information using Google. Your Google works as good as mine;)
