I know this should be pretty easy but I can't seems to wrap my head around creating this circuit.
The scenario is when the switch(S1) is closed, the lamp will turn on, when S1 is open, the lamp will turn off. There is an additional push button switch turning off the lamp but the lamp should not be back on until S1 is closed again.
The only restriction is that I can only use switches and relay, as I don't not have access to other hardware. I tried a few ways to connect a set and reset latch circuit but it doesn't fix the entire scenario that I wanted
Chua
Chua
