making a pcb
Discussion in 'General Electronics Chat' started by chrno, Dec 9, 2004.
  1. chrno
    Dec 9, 2004
    :D hi, i am a newbytes.
    i did a pcb using ultiboard 2001, when i tryd to print it, it don't do like it is suppose to be. i sending a picture of the print preview. like you can see yhe hole are not filled whit copper and traces pass through the hole, when thy are suppose to join to the hole's surrounding copper.
    may you tell me what can i do?
  2. chrno
    Dec 9, 2004
    :( why you don't answer my question.
    i need the answer previously the monday.
    please answer
  3. pebe
    Oct 11, 2004
    628
    I don't know Ultiboard 2001 so can't answer your question. But is it one of those multiuse programs that give the option of a PCB, a schematic, or a circuit simulator? If so, you may have picked the wrong program.
    Have you tried the 'help' files? Perhaps you should read the instructions again in case you missed something.
  4. Iodem_Asakura
    Sep 14, 2004
    140
    ultiboard is a pcb program only.
  5. chrno
    Dec 9, 2004
    that is correct.
    and i read the help file but in that file don't talk anything about that, that is the problem. :p
    whatever, thanks for try to help me :D
  6. dragan733
    Dec 12, 2004
    152
    Try to print the pcb on another computer. Maybe your comuter has a virus. Or direct to print for example on pdf format. And after to print the pdf file.
    I wait your answer
  7. chrno
    Dec 9, 2004
    look my computer don't have a virus, and print in pdf format don't solve anyting
